Leejo2005 Member
Posted: Tue Aug 31, 2010 4:30 pm Post subject: Intermittent wipers |
The wipers on my 83 firebird act as if in "Lo" mode when switched to delay/intermittent. As in they keep running. They park fine when turned off and work normally in the "lo" and "hi" modes. Any suggestions? _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
1967 Satellite Sport 383 |
fiveoformula Member
Posted: Tue Aug 31, 2010 10:32 pm Post subject: |
I had a similar problem with mine, ended up being the wiper module (black plastic case on the wiper motor) only when I would put the switch on Delay mode nothing happened, I just had Hi/Low.
Could be the switch aswell though I suppose. _________________
'88 FORMULA |
Leejo2005 Member
Posted: Wed Sep 01, 2010 3:17 pm Post subject: |
So The wipers have taken a back seat for now, the car's in the shop having the frame repaired. It finally cracked near the steering gear box. I have a steering brace for it but it looks like it had already cracked. They said they've seen this quite a bit on these and will reenforce the frame a bit to keep the steering crisp. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
