turbo_jimi Member
Posted: Sat Aug 14, 2010 8:44 pm Post subject: Camaro Garage 8/14/10 |
Good news is that I now have a horn and fewer oil and coolant leaks. Bad news is the car runs worse...after going to a vacuum advance type distributor. I'll let Aaron or John chime in on this to explain what it's doing so maybe there are some suggestions to remedy the problem. _________________
Posted: Sat Aug 14, 2010 8:52 pm Post subject: |
Bah. Crappy day. Been working on junk cars since 7:30 this morning.
Dizzy has to be out 45*. That's all I can figure. We didn't have a true dead-stop, but close as I can tell by dropping something down the cylinder the balancer mark is correct. Car acts like it's way too advanced, but when I pull the dizzy way back it runs like crap and stalls. Have to double-check that John and I stabbed it in the right spot, then go from there. |
Posted: Sat Aug 14, 2010 10:13 pm Post subject: |
I'm guessing that we screwed up the cap/rotor orientation when we were trying to keep that vacuum canister from deadending into the heater hose. Probably should have pulled the cap and double checked that the rotor was pointing at the proper post.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sat Aug 14, 2010 10:15 pm Post subject: |
Kinda hard in the dark.  |
Posted: Sat Aug 14, 2010 10:41 pm Post subject: |
| Rotor can point at any post. As long as you run the wires right. Makes no difference whatsoever. |
Posted: Sat Aug 14, 2010 11:09 pm Post subject: |
| chevymad wrote: | | Rotor can point at any post. As long as you run the wires right. Makes no difference whatsoever. |
I'm thinking I cocked it up somehow when I was moving them, or maybe went the wrong way. When I first stabbed the dizzy, the vacuum pod was clocked right into the heater hose. I pulled the dizzy forward 45*, then swapped all the wires back clockwise one post. |
Posted: Sat Aug 14, 2010 11:14 pm Post subject: |
| you didn't throw a timing light on it? |
Posted: Sat Aug 14, 2010 11:16 pm Post subject: |
| Timing light was reading normally. Had it at 4* before and it was knocking like crazy. |
Posted: Sat Aug 14, 2010 11:28 pm Post subject: |
Sounds like a bunch of newbs left unattended with a toolbox.
Firing order right?
I take it that you switched to a Non CC distributor. If so 4* BTDC is not enough base. Like 12* |
Posted: Sun Aug 15, 2010 12:06 am Post subject: |
C'mon, we're not complete noobs!  |
Posted: Sun Aug 15, 2010 7:49 am Post subject: |
| RSFreak wrote: | C'mon, we're not complete noobs!  |
Obviously we are, or the bish would be running.
Gotta get back under there; dead-stop to confirm tdc, timing tape so we can see how far and how fast it's advancing, double check the rotor position, triple check the firing order. |
Posted: Sun Aug 15, 2010 10:35 pm Post subject: |
I bet we pull the cap and find we are not lined up.  |
Posted: Mon Aug 16, 2010 7:09 am Post subject: |
If the timing light is on the timing mark.... and the balancer has not slipped.... and the firing order is right..... You're set.
Like said previously it doesn't matter where the distributor is and or rotor as long as the firing order is correct and oriented correctly on the cap for where the rotor is in relation to #1TDC F.S. _________________ A redline a day keeps the carbon away! |
Posted: Mon Aug 16, 2010 3:07 pm Post subject: |
| Twilightoptics wrote: | | ...and oriented correctly on the cap for where the rotor is in relation to #1TDC F.S. |
Like I said, this is where I think we screwed up. Easy fix.  |
Posted: Mon Aug 16, 2010 3:22 pm Post subject: |
Aaron said the timing light was reading right. There for #1 is in sync with the piston. Firing order and slipped balancer are the questionables. Set to about 10-12deg BTDC like Rodney said with the Vacuum advance disconnected. _________________ A redline a day keeps the carbon away! |
Posted: Mon Aug 16, 2010 4:41 pm Post subject: |
The more I think about it, the more I'm thinking firing order (and if it's on the driver's side, it's John's fault ).
I'm still gonna check the balancer (have to, at this point) but if the balancer was out, when I retarded the timing it should have ran great, not fell on it's face and stalled. |
Posted: Mon Aug 16, 2010 4:44 pm Post subject: |
When a balancer slips the engine will be in retarded timing at the specified mark. Think about how it spins. Crack moves clockwise from the front of the engine. If it slips, the crank turns but the balancer doesn't. So when you timing the engine on the mark, the ACTUAL TDC of the crank would be way off to the right in the ATDC area.
So you'd want to way increase timing based on the slip mark to make it run right. _________________ A redline a day keeps the carbon away! |
Posted: Mon Aug 16, 2010 5:02 pm Post subject: |
I was thinking about that backwards. I assumed that when the mark went back, it advanced it, but when the mark moves back, you move the distributor, which retards it.
This pretty much seals the deal on mixed up wires, because it was pinging and backfiring at 4* before, and wouldn't even crank over past 10* before. |
turbo_jimi Member
Posted: Mon Aug 16, 2010 5:28 pm Post subject: |
so, what needs to be done? _________________
Posted: Mon Aug 16, 2010 5:48 pm Post subject: |
Ignore where they've got the numbers on the cap. Just follow the order. Leave your #1 in place... and make sure the other 7 are right.
