Leejo2005 Member
Posted: Sat Aug 21, 2010 6:03 pm Post subject: T5 troubles |
So I was nearly finished with my T5 rebuild when I discovered that my case has been destroyed.
The rear bearing on the output shaft failed prior to rebuild and spun its race in the housing. The housing has worn and won't properly retain the new bearing race.
Is there anything I can do to fix it short of replacing the whole case? _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
1967 Satellite Sport 383 |
Posted: Sat Aug 21, 2010 10:02 pm Post subject: |
Case.
Call my old shop www.garagemotorsports.com for a case _________________ A redline a day keeps the carbon away! |
Leejo2005 Member
Posted: Sat Aug 21, 2010 10:20 pm Post subject: |
Once again I have made an ass out of myself...
The extension/tailshaft housing retains the aft output shaft retaining cup once installed. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
Posted: Sun Aug 22, 2010 8:36 am Post subject: |
I figured you were talking about the tail. _________________ A redline a day keeps the carbon away! |
