Tailshaft.
PostPosted: Wed Jul 21, 2010 1:48 pm    Post subject: Tailshaft. Reply with quote
Are the V6 and V8 T5 tail housings the same?
Mine has a small dent and a crack is starting to form right by the output shaft seal, and I think that might be the source of my slow leak of trans fluid.
PostPosted: Wed Jul 21, 2010 3:28 pm    Post subject: Reply with quote
They are the same as long as you get one for the proper speedo hole. IE-Mechanical or Tone wheel. NWC and WC are the same in relation also.
PostPosted: Fri Jul 23, 2010 5:21 pm    Post subject: Reply with quote
I have the old V8 T5 sitting in the back yard. If you want the tailshaft it is yours if you take the whole thing. Let me know.
PostPosted: Fri Jul 23, 2010 8:06 pm    Post subject: Reply with quote
not sure that'll work if it has the tone wheel. Mine is a cable driven.
PostPosted: Fri Jul 23, 2010 8:20 pm    Post subject: Reply with quote
What was wrong with that thing again? I might take it off your hands? I'd like to tear down a t5 for learnings.
PostPosted: Fri Jul 23, 2010 11:51 pm    Post subject: Reply with quote
It wont have the tone wheel. No NWC trans had tone wheels. VERY few thirdgens had tone wheels.
PostPosted: Sat Jul 24, 2010 8:05 am    Post subject: Reply with quote
All firebirds after 87 had electric vss'. Wouldn't they all have a tone wheel?
PostPosted: Sat Jul 24, 2010 8:20 am    Post subject: Reply with quote
It's a gear driven vss.
PostPosted: Sat Jul 24, 2010 8:21 am    Post subject: Reply with quote
eeeeeenteresting. Smile
