Yard watch: July 17th
PostPosted: Sat Jul 17, 2010 2:53 pm    Post subject: Yard watch: July 17th Reply with quote
Two new thirdgens at the McChord Pull-A-Part:
Black '86 or '87 Sport Coupe. 2.8L/700R4 car. No GFX. A/C delete car complete with dash and box. Mostly complete black interior (no seats)(James, you want black parts to complete my set?). Only problem is this car was seemingly previously owned by John, because it was full of wasps who did not seem particularly pleased withe me pulling the hood off of their home. As such, the A/C delete box remains out there. Doh!
Red '90 Firebird. 3.1/700R4 car. Hood front bumper and fenders are no good, everything else looks good. Interior is grey and mostly there (no seats).
If anybody wants anything off of either car, I will pull and sell any part for shipping + yard fees.
PostPosted: Sun Jul 18, 2010 10:31 am    Post subject: Reply with quote
I've had a problem with wasps at that Pull-a-Part before also. Sad
PostPosted: Sun Jul 18, 2010 12:10 pm    Post subject: Reply with quote
Well, bring your spray and we'll get that delete box. Wink
IROC-stangs
PostPosted: Sun Jul 18, 2010 7:22 pm    Post subject: Reply with quote
Not to thread jack or nothing but I didnt want to do a new thread and get bi*ched out, my friend's dad took his 88? maybe 89 sport coupe to the junker a few days ago, Sorry I cant remember were though (Maybe corvallis). I'll find that out. But trust me, this thing is rotted out pretty good if I remember right, has t-tops and a v6 thats all I know pretty much, sorry.
PostPosted: Tue Jul 20, 2010 12:48 pm    Post subject: Reply with quote
I need a delete box as long as it's not cracked or chipped. You mind pulling it for me?
PostPosted: Tue Jul 20, 2010 5:07 pm    Post subject: Reply with quote
Dan already has dibs on it. Now I just need to man up and kill those damn wasps.
Ran in to their buddies at my work today. Not enough cold weather last winter, so now the little punks are coming out of the woodwork.
PostPosted: Tue Jul 20, 2010 5:24 pm    Post subject: Reply with quote
Laughing Dane Cook flashback... "I'd punch every bee right in the face!"
PostPosted: Tue Jul 20, 2010 7:00 pm    Post subject: Reply with quote
[quote="aaron_sK"]Ran in to their buddies at my work today. Not enough cold weather last winter, so now the little punks are coming out of the woodwork.[/quote
Took two full cans of Raid to kill the little bastards in my wheel well! When I knocked the nest off the car there were about 70 little bee bodies on the ground! Twisted Evil
kurfbird
PostPosted: Tue Jul 20, 2010 8:43 pm    Post subject: Steering Column 90 bird Reply with quote
Aaron I need the steering column from a 1990 bird. Needs to be in good condtion. Either you could pull it for me and I will be down your way on saturday.
Or jsut let me know it conditon so I can go to pick and pull if necessary
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Tue Jul 20, 2010 8:48 pm    Post subject: Reply with quote
IIRC the column in the Bird had been dropped for them to pull the gauges. The wheel was intact, along with the airbag cover. No blinker stalk (I took that Wink). You just want the column, or the wheel too?
We will be in Portland Saturday, but if you want to swing by my house I can leave it in front of my shop. I moved (again) since the last time you came by though. Laughing
kurfbird
PostPosted: Tue Jul 20, 2010 9:26 pm    Post subject: I just need the column Reply with quote
I just need the column. I need it to be tight dont need one with slop ahve that already
Also looking for a throttle body for the 3.1
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Tue Jul 20, 2010 9:55 pm    Post subject: Re: I just need the column Reply with quote
You torn it apart? Alot of times it's just the 4 invert torx screws that loosen up, and cause it to be floppy.
kurfbird
PostPosted: Tue Jul 20, 2010 9:58 pm    Post subject: column Reply with quote
Mine has a problem with the blinker switch assembly. and the clock asembly for the air bag
Every time I ahve taken one of these apart been nothing but problems
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Tue Jul 20, 2010 10:32 pm    Post subject: Reply with quote
Not many '90 - '92 f-bodies in yards around here. Pick-A-Part in Tumwater probably has one. And they've got 2.8 and 3.1 TBs laying around all over the place! Cool
PostPosted: Sun Jul 25, 2010 12:46 pm    Post subject: Reply with quote
Found a set of 16X8 4th gen salad shooter wheels at the yard in Poulsbo. Didn't have the cash, nor the space in the car to pick them up. The guy at the counter said $100 for all four. They're not perfect by any means, but very usable. One has a slightly bent bead and a scuff on one of the spokes and another has a fair amount of curb rash on it. 3 are missing center caps. If anyone is interested, I can go get them.
PostPosted: Fri Jul 30, 2010 7:57 am    Post subject: Re: I just need the column Reply with quote
Where exactly are those for screws, and what needs to removed to get to them?
I am picking up an 86 today that has the column so loose that the ignition guts all fall apart and the steering lock will lock itself even with the key on. So either it is just real loose or I need a new column, I'd rather check for loose screws first.
Killing mailboxes since 2009
PostPosted: Fri Jul 30, 2010 4:33 pm    Post subject: Reply with quote
You have to tear the column all the way down past the flex joint. Remove wheel, turn signal switch, key/tumbler, upper housing, spring, pull the 2 pins from the sides of the lower housing, unlatch the tilt latch then pull lower housing off of steering shaft.. now you should be able to see the screws.
PostPosted: Fri Jul 30, 2010 4:36 pm    Post subject: Reply with quote
Side pins come out with a cheap tool from schucks.
PostPosted: Fri Jul 30, 2010 5:20 pm    Post subject: Reply with quote
Don't even need the tool. Just get some long bolts (M5 or something), fender washers for them, and some big nuts to use as puller spacers. Wink
I am debating on the wisdom of sending flea into a GM steering column. This is a man who is stymied by a hatch pulldown motor. Wedgie time!
PostPosted: Fri Jul 30, 2010 6:00 pm    Post subject: Reply with quote
Well, you might have a point there. Pull down still doesn't work, mostly money there. Wind shield wipers still don't work, now I'm not sure if the air bag will work or not, the idiot light aka flea sensor is illuminated indicating problem with the air bag. But more seriously I really need to just replace the entire colomn, its held together with two big a$$ hose clamps, a piece of tin and masking tape. Yep masking tape, not even duct tape. So even if I do tighten it up its still ghetto even for the ghetto
