IROC-stangs Member
Posted: Mon Jun 21, 2010 1:53 pm Post subject: wtf can i do? |
ok so recently i got about dollar bill sized dent on the roof right behind the t-tops on the edge, was told by neighbor to remove interior pieces and see if we could pop it out from there, well i got the interior pieces out but there is what i guess is called roll bar structure in the way and shouldnt be removed unless absolutely needed.
so is there any other way to get the dent out other then getting it popped out or drill holes in it? i dont have (and wont have) 500 dollars to repaire it and the car looks so bad with it and so any ideas on what to do?
im considering storing the car but how much could that run me at an decent place and where? thanks. |
Posted: Mon Jun 21, 2010 4:26 pm Post subject: |
What caused the dent? Sometimes if the metal isn't creased and the dent isn't too bad you can pop a smallish dent out with dry ice applied to the outside.
Only other option realistically is to take the car to a PDR specialist and get it popped back out. If you don't know already, PDR means paintless dent repair, so called because a repaint is not necessary after the work is completed.
Good luck. _________________ 84 Camaro Z28 - LS1/T56
IROCDave Member
Posted: Mon Jun 21, 2010 4:39 pm Post subject: |
| You could try a large suction cup, like the ones used by Glazer's. I have a 8" cup thats good for 300lb's that I used to use for setting wood doors. If it's on a the radiused portion of the roof it wont work though. |
IROC-stangs Member
Posted: Mon Jun 21, 2010 10:39 pm Post subject: |
| a metal portable camping oven fell down from boxed in my garage. i hope i dont have to take it anywhere, i was thinking of using the suction cup thing, might not work but for 2.99 its worth a try. |
Posted: Tue Jun 22, 2010 6:00 pm Post subject: |
Wouldn't a body hammer on the inside of the roof skin work? I haven't seen a naked thirdgen roof interior in several years so I'm having trouble picturing the "roll bar structure" you mentioned. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Tue Jun 22, 2010 6:04 pm Post subject: |
| t-top cars have the center brace that runs there, getting easy access to the roof skin might not be too easy. |
IROC-stangs Member
Posted: Tue Jun 22, 2010 6:48 pm Post subject: |
| ya no way in hell to get to the body "skin". anyone mind taking a bit of their time to help me in the next few yrs to put the interior back in correctly? rofl i suck at putting stuff together. |
Posted: Tue Jun 22, 2010 8:27 pm Post subject: |
| IROC-stangs wrote: | | ya no way in hell to get to the body "skin". anyone mind taking a bit of their time to help me in the next few yrs to put the interior back in correctly? rofl i suck at putting stuff together. |
Take it slow, don't force anything (its 20yr old ABS plastic, and it will crack or break). A little common sense an afternoon and it shouldn't be a problem.
This is a good chance to learn! _________________
IROC-stangs Member
Posted: Tue Jun 22, 2010 9:48 pm Post subject: |
| Quasi-Traction wrote: | | IROC-stangs wrote: | | ya no way in hell to get to the body "skin". anyone mind taking a bit of their time to help me in the next few yrs to put the interior back in correctly? rofl i suck at putting stuff together. |
This is a good chance to learn! |
ya true, i got it thrown together so its ok for now, one thing i hate about thirdgens, there WAYYYYY to cramped in the rear passenger area. |
Posted: Tue Jun 22, 2010 9:57 pm Post subject: |
| Back seat was only put in 3d gens for insurance purposes.. it was really not meant to be used. |
Posted: Tue Jun 22, 2010 9:58 pm Post subject: |
| You should only have had to take off the one cross panel that goes between the headliner and the rear hatch glass. That clips into the B-panels on each side. Like four screws. Pretty simple. |
IROC-stangs Member
Posted: Tue Jun 22, 2010 10:07 pm Post subject: |
| chevymad wrote: | | Back seat was only put in 3d gens for insurance purposes.. it was really not meant to be used. |
not really looking to removing the rear seats, as im going need them sometime or another, plus i always though as it as something kinda "kiddy" |
IROC-stangs Member
Posted: Tue Jun 22, 2010 10:08 pm Post subject: |
| aaron_sK wrote: | | You should only have had to take off the one cross panel that goes between the headliner and the rear hatch glass. That clips into the B-panels on each side. Like four screws. Pretty simple. |
i took off alot more then that lol, just kinda went ahead and took everythigng out in that area  |
Posted: Tue Jun 22, 2010 10:16 pm Post subject: |
| IROC-stangs wrote: | | aaron_sK wrote: | | You should only have had to take off the one cross panel that goes between the headliner and the rear hatch glass. That clips into the B-panels on each side. Like four screws. Pretty simple. |
Sorta like when you tried to change an alternator and came in here trying to figure out how to reinstall a neg batt cable; a part you should not have to remove to R&R an alt. |
Posted: Tue Jun 22, 2010 10:18 pm Post subject: |
pfff, i take everythign apart wether i need to or not. It makes it more fun.
(That might be why i never finish stuff) |
IROC-stangs Member
Posted: Tue Jun 22, 2010 10:23 pm Post subject: |
| aaron_sK wrote: | | IROC-stangs wrote: | | aaron_sK wrote: | | You should only have had to take off the one cross panel that goes between the headliner and the rear hatch glass. That clips into the B-panels on each side. Like four screws. Pretty simple. |
wtf isnt that kinda what a fourm is for, TO HELP OTHERS??? wtf else was i suppose to do, aint got the money to take it to a shop, atleast i tried. |
| Dewey316 wrote: | | (That might be why i never finish stuff) |
Confucius say: He who has disassembly ADHD will always have a large pile of parts, and a broken Audi.
*Edit: @ IROC-stangs: I got nothing against helping people on here. If I recall we helped you fix your battery cable problem. My point was merely that you need to learn not to over-disassemble, and that previous experience should show you that.  |
IROC-stangs Member
Posted: Tue Jun 22, 2010 10:28 pm Post subject: |
| yes i appreciate the help very much, i just dont want people saying i shouldnt do something when its my only option. |
