camaro died again...
91camaro_rs
PostPosted: Mon Aug 30, 2010 11:27 pm    Post subject: camaro died again... Reply with quote
ok so drove my car about 30 miles to movie theatre and back, then on my way to work it died, the motor seemed pretty hot, i didnt pay attention to the temp guage when it died so idk what it was at. but i checked for spark, and nothing. and i just put in a new distributor, ignition module and pickup coil. the coil is a MSD streetfire coil, i bought it new when i started the swap so about april. coil and distributor are under warranty so i thought i would swap em out tomorrow.
this happened about 3 days ago too, but it just started after about 5 mins.
anyone know why it just randomly loses spark?
(idk if anyone has texting but i have court in the morning and wont have time to check the computer except in the morning at 6am, so it would be cool if someone could call or text me if they know what might be going on with my car) number is 253-224-9795
thanks guys
PostPosted: Tue Aug 31, 2010 5:45 am    Post subject: Reply with quote
Verify power to the IGN Module and Coil.
PostPosted: Tue Aug 31, 2010 10:39 pm    Post subject: Reply with quote
What he said, and That high voltage coil might not agree with that stock replacement distributor.
91camaro_rs
PostPosted: Wed Sep 01, 2010 12:29 am    Post subject: Reply with quote
ICM fried and coil pigtails have broken wires in them but got em to work, put in a new dizzy and re timed it in a church parkin lot haha
new pigtails will be in today
PostPosted: Wed Sep 01, 2010 12:35 am    Post subject: Reply with quote
Glad you figured it out. Smile
91camaro_rs wrote:
ICM fried
Thats what kept happening to my car when I had an Accel coil in it. Hope it doesn't pop again.
91camaro_rs
PostPosted: Wed Sep 01, 2010 12:50 am    Post subject: Reply with quote
yeah, i have a MSD streetfire coil right now, if it blows the ICM again i might just run a stock one, if that would help at all
PostPosted: Wed Sep 01, 2010 5:44 am    Post subject: Reply with quote
Coil shouldn't hurt the ICM. These ICM are 12v. Only time you run into that trouble is when the system calls for a ballast resistor or resistor wire. Ours don't.
PostPosted: Wed Sep 01, 2010 9:20 am    Post subject: Reply with quote
I kept having problems with aftermarket ICM's. I had to put a delco back in.
91camaro_rs
PostPosted: Wed Sep 01, 2010 11:14 am    Post subject: Reply with quote
i think someone might have stuck a screwdriver in my driver door lock when it was sitting over night, my driver door will no longer work with a key, is there any way i can get a new cylnder for the key i have or do i just need to get a new one with new key
PostPosted: Wed Sep 01, 2010 11:43 am    Post subject: Reply with quote
You can buy a cylinder and have it recoded to your current door key if you want. Security lock and safe on 6th ave in Tacoma used to do it for my dealership for ~$25.
PostPosted: Thu Sep 02, 2010 12:09 pm    Post subject: Reply with quote
I got one out of a junkyard car for free when I got other stuff. Then had the locksmith around the cornor re-key it for 10 bux.
Easy to do, just time consuming to pull door panel n all that junk off.
PostPosted: Thu Sep 02, 2010 7:32 pm    Post subject: Reply with quote
I forgot about you running a divorced coil. The pigtails getting bent over and crapping out is not a new thing, same thing happened on my IROC.
