batcave Member
Posted: Thu May 27, 2010 3:45 pm Post subject: gauges stopped working |
| my gauges in my 89 gta stopped working where should i look for the short at i tore the hole dash out couldnt find any wires that were shorted could it be inside the steering column any good electrical shops in vancouver i cant find the problem any help appreciated this car has been parked in my garage for 6 years in dry storage thanks |
IROCDave Member
Posted: Fri May 28, 2010 1:03 pm Post subject: |
First thing to do would be to check the fuses in the fuse panel, then make sure the wiring harness is fully engaged into the printed circuit board on the back of the gauge cluster.
I would also suggest adding a couple of periods to your posts  |
Posted: Fri May 28, 2010 1:39 pm Post subject: |
| IROCDave wrote: | | make sure the wiring harness is fully engaged into the printed circuit board on the back of the gauge cluster. |
^ This.
| IROCDave wrote: | I would also suggest adding a couple of periods to your posts  |
^ And also this.
Chebby clusters have a habit of pushing the harness contact plug back, or at a funny angle, which causes them to lose ground or power, and weird electrical gremlins ensue. |
alloy T56 Elitist
All Star auto electric on highway 99 in Hazel Dell _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
