update on the camaro
91camaro_rs
PostPosted: Thu May 27, 2010 1:11 pm    Post subject: update on the camaro Reply with quote
so after having this thing towed around Gig Harbor numerous times to different shops...well its back at my house, running a lot better, it was something to do with timing, so im fine tuning the timing now, i almost got it!! got a new map sensor( one for a v8 lol)and VSS sensor and TV and accelerator cables are on the way. also got tranny fluid and a new filter and gasket.
i looked at my book and it said 700r4's take 5 quarts excluding the Torque converter, should i just put in 5 after i dump the stuff in it now or should i do 4 and slowly add and check putting the 5th in?
PostPosted: Thu May 27, 2010 3:59 pm    Post subject: Re: update on the camaro Reply with quote
Good deal Luke. Was the distributor stabbed wrong? I seem to recall timing it to around 6*btdc.
Measure how much comes out.
Honestly though, if you've got a working 700R4, I'd go around that thing like a stack of cards. No fluid flush.
91camaro_rs
PostPosted: Thu May 27, 2010 10:02 pm    Post subject: Reply with quote
idk if it was stabbed wrong or not, but the timing is almost perfect, ill get it done tomorrow, its running soooo much better tho than it did, i hope it drives now!
