chevysquid Member
Joined: 28 Dec 2007 Posts: 72 Location: Coupeville, Washington
Posted: Tue Jun 22, 2010 6:51 pm Post subject: Need a fan shroud |
I have a mechanical fan on my 86 with a 350. It has a single E-fan upper on it now with both corners broken so it is doing no good. Would like to find a shroud for the clutch fan, but an upper for an electric fan would work too. Just don't want one of the V-6 ones with the radiator hose support on the passenger side. Might consider just switching it all over to electic fan or dual fans if I found a great deal. _________________ 1986 IROC Z-28 |
Posted: Tue Jun 22, 2010 7:04 pm Post subject: |
FYI, the 3.1 V6 radiators are the same as the V8, so the upper support is the same, mine is. Should give you some more options. _________________ 92 Camaro
chevysquid Member
Posted: Tue Jun 22, 2010 7:12 pm Post subject: |
Good to know, I saw a V-6 w/the support on the passenger side and figured they were all that way. _________________ 1986 IROC Z-28 |
