popballz Member
Posted: Mon May 10, 2010 11:48 am Post subject: v8 auto transmission |
My transmission is going out and I will need another one for a couplee months.
I have a manual trans to go in, but I do not have time to do that swap right now.
So does anyone have a CHEAP auto transmission that will last me a couple months??[/quote] _________________ -Donald
Posted: Mon May 10, 2010 11:52 am Post subject: |
C'mon if you have everything it doesn't take much more time to swap the T5 in than it does to R&R an automatic.
There are enough of us guys that might be willing to work for Beer/Pizza in the Tacompton/Seattle area that I'm sure we could get you rowing in no time. Especially if you have access to an air compressor. _________________ A redline a day keeps the carbon away! |
Posted: Mon May 10, 2010 2:36 pm Post subject: |
| Twilightoptics wrote: | | There are enough of us guys that might be willing to work for Beer/Pizza in the Tacompton/Seattle area that I'm sure we could get you rowing in no time. Especially if you have access to an air compressor. |
^ This. ^
We'll be busy on the 22nd, and we need to change John's clutch at some point, but buy the swap stuff, and throw a weekend out there Donald. I'll show up with my topbox.  |
popballz Member
Posted: Mon May 10, 2010 4:44 pm Post subject: |
I have been looking for the parts!
But all I have is the transmission
Any good place to look for those parts??
I am driving in d2 because there is no third gear in d or od
How long can I drive in d2?? _________________ -Donald
Posted: Mon May 10, 2010 6:33 pm Post subject: |
Clutch material in the fluid means I'd imagine you wont be driving around in second for long. When the 700 in the IROC blew the fluid went from bright red to dark grayish-brown immediately. Plus the top speed of like 40 kinda sucks.
Try the Pull-A-Part by McChord. They rarely have a decent turdgen there, but if they do it's like less than $100 for everything including a transmission.
If not, try the one in Tumwater. |
kurfbird Member
Posted: Mon May 10, 2010 8:58 pm Post subject: 700r4 |
A pick up trasnmission will work also. Same trans as long as they are the same length.
I will have a 700r4 in a few weeks going to replaced my wifes one with a new one.
Also have a slave cylidner and and set of pedals. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
popballz Member
Posted: Mon May 10, 2010 10:34 pm Post subject: Re: 700r4 |
| kurfbird wrote: |
Also have a slave cylidner and and set of pedals. |
With the clutch pedals??
How much you want?? _________________ -Donald
86toy Member
1986 Pontiac Trans Am
Posted: Wed May 12, 2010 6:11 pm Post subject: |
i heard all auto wrecking on mountain highway has a few third gens out there, the ones at pull apart are v6 cars. _________________ 86 t/a 305 tpi 700r4 3.73 possi 4 wheel disc
245/45/17 restoring |
Posted: Wed May 12, 2010 6:20 pm Post subject: |
| 86toy wrote: | | i heard all auto wrecking on mountain highway has a few third gens out there |
They'll be out there awhile longer if their prices don't come down. |
kurfbird Member
Posted: Wed May 12, 2010 7:12 pm Post subject: V6 700r4 |
I have a low mileage 700 r4 v6 only 96,000 from a 87 firebird. Wiith torque converter. 100.00 _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
91camaro_rs Member
Posted: Wed May 12, 2010 10:08 pm Post subject: Re: V6 700r4 |
| kurfbird wrote: | | I have a low mileage 700 r4 v6 only 96,000 from a 87 firebird. Wiith torque converter. 100.00 |
he needs a V8 tranny... |
kurfbird Member
Posted: Wed May 12, 2010 11:57 pm Post subject: Oops |
Oops I looked at the info on his car _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
91camaro_rs Member
Posted: Thu May 13, 2010 12:20 am Post subject: |
| his 87 has a v8 and 89 has V6 |
popballz Member
Posted: Thu May 13, 2010 10:55 am Post subject: Re: V6 700r4 |
From a v6? That's not the same as a v8 transmission is it?? _________________ -Donald
kurfbird Member
Posted: Thu May 13, 2010 12:04 pm Post subject: V6 trnamission |
No there are different. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Tue Jun 15, 2010 1:00 pm Post subject: |
I have an '85 700r4 from my camaro for $150 if you want it. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
alloy T56 Elitist
Posted: Tue Jun 15, 2010 1:33 pm Post subject: |
I've got a clutch reservoir with bracket for $15 and the ride there. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
popballz Member
Posted: Wed Jun 16, 2010 11:57 am Post subject: |
replacement is already in. _________________ -Donald
