Need good juju...
PostPosted: Fri Oct 01, 2004 10:03 am    Post subject: Need good juju... Reply with quote
Crewbies,
Please send your good vibes, happy thoughts, karma, luck, cross your fingers or whatever else you can do for my luck.
I got the heads back from the shop yesterday. Me and Paully put them on, set lash, etc. Tonight I will continue the re-assembly. Hopefully the Sled will be back on the road Saturday and happy with her increased compression.
I would really like to be done with the fricking hassles for a while so send the good juju!
THANKS!
BTW - Paul once again worked his butt off on my car. So many of you have helped me since I joined up with this Motley crew a few years ago. Many thanks!
PostPosted: Fri Oct 01, 2004 10:40 am    Post subject: Reply with quote
I sacraficed 3 gummie bears on top of my monitor to the red sled gods. I'm thinking good thoughts for you (although I would like ot beat you at the strip :p)
PostPosted: Fri Oct 01, 2004 10:47 am    Post subject: Reply with quote
Please tell me they were virgins Wink
Thanks Dewmeister!
Midnight Sun
PostPosted: Fri Oct 01, 2004 12:09 pm    Post subject: Reply with quote
Good luck Very Happy
PonchoTA
PostPosted: Fri Oct 01, 2004 12:52 pm    Post subject: Reply with quote
Karn, the Good Luck Troll! If you rub his tummy, you'll have good luck!
Paully
PostPosted: Fri Oct 01, 2004 1:02 pm    Post subject: Reply with quote
Now we are cooking... we have rabbits feets and Karnage! (belly has been rubbed as requested although the nippleage is a little disturbing Wink )
PostPosted: Fri Oct 01, 2004 1:50 pm    Post subject: Reply with quote
Stupid cardomain wont host my picture. Jess, when we gonna get pic hosting on here? Wink
Midnight Sun
PostPosted: Fri Oct 01, 2004 4:09 pm    Post subject: Reply with quote
www.imageshack.us
PostPosted: Fri Oct 01, 2004 4:44 pm    Post subject: Reply with quote
PostPosted: Fri Oct 01, 2004 5:08 pm    Post subject: Reply with quote
LMAO!
PostPosted: Fri Oct 01, 2004 11:19 pm    Post subject: Reply with quote
This help Wink
Jess
Administrator
PostPosted: Sat Oct 02, 2004 10:32 am    Post subject: Reply with quote
Let me make some changes to the FTP and see if I can't get a image directory set up.
Demon
PostPosted: Sat Oct 02, 2004 8:56 pm    Post subject: Reply with quote
http://www.celerondude.com/index.php?a=s
use his uploader script... it's quite nice
Soon to be less than stock
PostPosted: Mon Oct 04, 2004 11:23 am    Post subject: Reply with quote
Well she is running. Need to set the valve lash again... sounds like i have a few noisy lifters. Also need to tune again. A full point of compression changes things apparently.
Still have an issue at high rpm decel (like from 6k in second and let off) where I get a nice blue cloud out the back. The original assumption there was that the valve seals were toast which while true did not fix this issue.
Butt dyno says more power but BD lies sometimes.
Thanks for the happy thoughts and ju-ju b's Wink
Wolffy
PostPosted: Mon Oct 04, 2004 11:27 am    Post subject: Reply with quote
it sucks that your original issue aint resolved....yet
take a deep breath & no not of the exhaust & tackle it again
more horsies are always good
maybe you should consider changing the name of your car from the RED sled to the RED gremlin Bashy Bashy
PostPosted: Mon Oct 04, 2004 11:35 am    Post subject: Reply with quote
methinks that the original issue is that i thought it would be a good idea to work on my own car Laughing
Embarassed
PostPosted: Mon Oct 04, 2004 11:36 am    Post subject: Reply with quote
It was running good when I drove it, then you touched it Wink
PostPosted: Mon Oct 04, 2004 11:45 am    Post subject: Reply with quote
ahhhh NOW we know what happend... Dewey drove it!
