Free Chevy 307
PostPosted: Sun Apr 04, 2010 12:42 pm    Post subject: Free Chevy 307 Reply with quote
Free Chevy 307, can be picked up at my house...intake manifold not included.
Thank you,
PostPosted: Sun Apr 04, 2010 3:02 pm    Post subject: Reply with quote
I'll see if I can arrange pickup, can you give me a week or two?
PostPosted: Sun Apr 04, 2010 6:51 pm    Post subject: Reply with quote
the 17th would be great!
PostPosted: Sun Apr 04, 2010 8:10 pm    Post subject: Reply with quote
This was the engine that was going in my T/A until we found out it was a 307. It may be good as a core to be rebuilt, but it has been out in the elements for a while so there is quite a bit of rust on it.
PostPosted: Sun Apr 04, 2010 8:26 pm    Post subject: Reply with quote
heads are a little rusty, but we painted it early on and it does have the intake manifold on it, so not that bad
PostPosted: Sun Apr 04, 2010 8:35 pm    Post subject: Reply with quote
Quite a bit of water probably got into the open manifold, the intake runners, and the open valves into the cylinders. I just don't wanna misrepresent this engine. Wink
PostPosted: Sun Apr 04, 2010 8:50 pm    Post subject: Reply with quote
will the crank rotate freely, or have you tried recently?
PostPosted: Mon Apr 05, 2010 9:52 am    Post subject: Reply with quote
never tried it
PostPosted: Mon Apr 05, 2010 5:52 pm    Post subject: Reply with quote
Go outside and try it! Very Happy
PostPosted: Mon Apr 05, 2010 6:14 pm    Post subject: Reply with quote
Pour a little diesel or ATF down it tonight, then try it tomorrow. You'll have better luck.
PostPosted: Mon Apr 05, 2010 6:26 pm    Post subject: Reply with quote
the wheel that the engine is sitting on is keeping the crank from turning
PostPosted: Mon Apr 05, 2010 7:49 pm    Post subject: Reply with quote
I think I may have a truck to bring up and grab this. Basically what I'm interested in is the crank and possibly the rods. Realistically, I'll probably scrap the rest.
PostPosted: Mon Apr 05, 2010 8:20 pm    Post subject: Reply with quote
I'm sure James' wife will appreciate getting it out of the yard! Very Happy
PostPosted: Tue Apr 06, 2010 7:36 am    Post subject: Reply with quote
She sure will! Very Happy
PostPosted: Tue Apr 06, 2010 7:40 am    Post subject: Reply with quote
I would think a 307 would make a fine little flower pot.
PostPosted: Tue Apr 06, 2010 3:06 pm    Post subject: Reply with quote
I would at least hold a few more flowers than a 305. Flowers don't give a shizzle about stroke. Laughing
Their all about the bore!!
307 with 416 heads cut for 1.94" valves
XE262 cam
decent intake / carb / exhaust
easy 250 hp at the crank
PostPosted: Tue Apr 06, 2010 3:16 pm    Post subject: Reply with quote
I'd say easy 250 at the wheels.
PostPosted: Tue Apr 06, 2010 4:00 pm    Post subject: Reply with quote
ehhh, I don't see that. That takes 1 per inch and those 416's aren't going to cut it there.
PostPosted: Tue Apr 06, 2010 4:31 pm    Post subject: Reply with quote
Well when stock 305s with decent stock cams put out 225 on the ground... I dont see why some decent 416s with bigger valves, and a performance cam couldn't squeek out 25hp without a sweat.
PostPosted: Tue Apr 06, 2010 4:40 pm    Post subject: Reply with quote
Torque would be down, hp up from a 305. Same cubes but alot less valve shrouding then the 305. I think it would make an interesting tpi experiment.
