Horsepower
Goto page 1, 2, 3  Next
PostPosted: Mon Mar 08, 2010 8:16 pm    Post subject: Horsepower Reply with quote
I'm thinking we probably should try to move/keep the horsepower replies out of the picture post. Pic post is pretty big as it is. Maybe when shultz comes on he can move them.. Anyway, here's my #s for the 2nd gen.. sad as they are.
237hp/305tq
This is at 4k rpm since my fuel pump can't keep up with my carberator.. Discovered last night that pontiac made 2 different pumps. 1 for a 2 barrell.. which i have.. and one for a 4 barrel. I'm told the 2 barrel pump cannot keep up with a stock 4 barrel.. I've got a bit of a learning curve going on with this poncho motor.
I also have a heat problem causing detonation, Steve stopped my last 2 runs because of this. Possible transmission problems and an intermittant rear brake drag.. when I get these problems solved I expect a few more hp.. maybe with that and a real exhaust I could be pushing 280-300.. I hope!! Wink
PostPosted: Mon Mar 08, 2010 8:21 pm    Post subject: Reply with quote
Mine did slightly better this time than last. Might have been the weather Laughing No power mods were done to the car, but there was a rear end gear change which should have no effect.
169hp/250tq
PostPosted: Mon Mar 08, 2010 8:30 pm    Post subject: Reply with quote
Weather should be factored in with the correction. I like my uncorrected numbers.. 250hp! lol.
PostPosted: Mon Mar 08, 2010 8:42 pm    Post subject: Re: Horsepower Reply with quote
If you're running out of fuel, isn't it going to ping and get hot regardless though? Confused
PostPosted: Mon Mar 08, 2010 8:51 pm    Post subject: Reply with quote
My afr was fine.. til about 4500.. then it went straight up. But amazingly that first run didnt ping. The next 2 after it had warmed up pinged badly.
PostPosted: Mon Mar 08, 2010 9:12 pm    Post subject: Reply with quote
Yeah, I figured that, hence the smiley...
PostPosted: Mon Mar 08, 2010 9:55 pm    Post subject: Reply with quote
Ahh... somehow I was thinking you were lean throughout.
Just for S&G's I overlayed the Monterey's runs with the IROC's runs from last year. The similarity of the HP curve is shocking. The only real difference is that it just keeps going, instead of the TPI nosedive.
The problem with the Monterey is illustrated pretty clearly in the lower panel, however. Embarassed
PostPosted: Mon Mar 08, 2010 11:33 pm    Post subject: Reply with quote
What RPM was the peak hp and tq at?
283hp @ ~5250
316tq @ ~4000
I want moooorrreee powah!!
I noticed the bird has 290lb/ft tq @ 1900rpm. Laughing I like torque tables.
PostPosted: Mon Mar 08, 2010 11:45 pm    Post subject: Reply with quote
I need ALOT more power in my Daytona Crying or Very sad 130.64 hp and 162.73 tq i need more boooooost !
PostPosted: Tue Mar 09, 2010 7:42 am    Post subject: Reply with quote
If it looks like a boat, and smells like a Yamaha outboard it must be...... A Monterey!
Mazda made:
111 HP
108 LB/FT
Up 23 from last years 88hp for a 26% increase! AND she's a full point lean at 13.5:1. Time to research how much to jet up!
And until my 4th run which was 5th gear top speed, it put out less smoke with an Oil Injection System! LOL Than most of the SBC!
PostPosted: Tue Mar 09, 2010 9:03 am    Post subject: Reply with quote
I think my oil injection system was malfunctioning. Laughing
PostPosted: Tue Mar 09, 2010 9:36 am    Post subject: Reply with quote
Lube the tube!
PostPosted: Tue Mar 09, 2010 12:17 pm    Post subject: Reply with quote
The Formula oiled down the pipes with 158HP and 252LB FT. Quite a bit better than the 129HP run last year as I corrected the lean condition. It was Pig rich this time.
'88 FORMULA
PostPosted: Tue Mar 09, 2010 12:51 pm    Post subject: Reply with quote
What were your AFRs? Time for N20? Very Happy
PostPosted: Tue Mar 09, 2010 5:45 pm    Post subject: Reply with quote
Hehe... Derrick's AFR had a big ol' hole in it.
Although since you have a high-mileage TBI 305, by crew logic you should put a gianourmous shot on it and be fine for years to come. Razz
PostPosted: Tue Mar 09, 2010 7:36 pm    Post subject: Reply with quote
fiveoformula wrote:
...and 3 more horses than Skyler!
Reeaal mature, Derek. Real mature... Smashy Smashy
PostPosted: Tue Mar 09, 2010 11:50 pm    Post subject: Reply with quote
Can't wait to get my T/A on the dyno next year! Very Happy Cool
PostPosted: Wed Mar 10, 2010 9:22 am    Post subject: Reply with quote
Hehe I think it's time!
The AFR's were like 10.3 all the way thru, but it had a wierd dip at about 4500rpm.
Kyleneon
New Member
1999 Chevrolet Camaro
PostPosted: Wed Mar 10, 2010 10:32 am    Post subject: Reply with quote
the little red ricer made
279
345
better then last years 260 with the dam over boost protection!!
99' Neon R/t boosted 300+rwhp
PostPosted: Wed Mar 10, 2010 10:47 am    Post subject: Reply with quote
No.... You need less boost or more fuel to get you out of the dangerous 14+:1 Ratio.
Think about it: Mopar 2.2L Turbo starting in 1984:
"Chrysler used a Garrett Research T-3 turbocharger, including an integral wastegate, with a maximum boost of 7.2 psi;"
Not 14. And not your 11psi. They cranked the boost without adding fuel. Good thing your motor is tired, all the boost pressure is just passing the rings and not blowing up!
What to know about your motor:
http://www.allpar.com/mopar/22t.html
Page 1 of 3
