IROC-stangs Member
Posted: Sun Mar 21, 2010 8:42 am Post subject: sticky tires |
ok this might sound as stupid as hell but here i go. ok lastnight at around 11am when it was around 40 or so degrees well i had the camaro parked at a angle to take some pictures and to clean her up and well i was going to jack up the rear of the car and do a lil washing underneath and when i started jacking it up and lifting up the rear tires you could here something on the tires when they were lifing up that sounded like if something is sticky and you are pulling it apart. so is this normal for all tires or do i actually have half azz decent tires? i cant think of the tire brand but the speed rating is like only 118 and there older 90's tires. |
TurdGen1989 Member
Posted: Sun Mar 21, 2010 8:47 am Post subject: |
idk if they are sticking but usually when you jacked the car up the tires are going sort of inward so they drag on the ground. unless your in a indoor garage sometimes they will stick. _________________ Phil.
GMC High Sierra
IROC-stangs Member
Posted: Sun Mar 21, 2010 8:51 am Post subject: |
TurdGen1989 wrote: | idk if they are sticking but usually when you jacked the car up the tires are going sort of inward so they drag on the ground. unless your in a indoor garage sometimes they will stick. |
ya i was jacking up the rear and everyother time i have though in the garage i never heard the sticking noise. also i was out in the driveway. |
Posted: Sun Mar 21, 2010 8:54 am Post subject: |
Couple of things:
Tires on the back of a solid axle car don't drop inwards when the car is raised (unless you burn up a bearing so bad the balls exit the race, but that's another story )
You were parked at an angle, and most likely had your front tires turned in. You don't want to raise both rear tires unless the fronts are pointed straight ahead, and blocked with wheel chocks.
All tires will scrub when the vehicle is raised. More so it's an independent suspension, on rough ground, or being jacked wrong causing excess movement. |
IROC-stangs Member
Posted: Sun Mar 21, 2010 9:03 am Post subject: |
aaron_sK wrote: | Couple of things:
i had the front tires turned pretty close to straight. |
Posted: Sun Mar 21, 2010 9:12 am Post subject: |
Had you recently done a burnout? If so the tires will get sticky too. |
Posted: Sun Mar 21, 2010 9:14 am Post subject: |
chevymad wrote: | Had you recently done a burnout? If so the tires will get sticky too. |
That might explain why he needed to clean up under there. |
IROC-stangs Member
Posted: Sun Mar 21, 2010 9:23 am Post subject: |
sadily nope been a while since that thing has even been peeled out in. but once i get my liscence+tags+insurance+title and whatever else = big burnout for the neighbor kids. |
flea Member
Posted: Sun Mar 21, 2010 10:25 am Post subject: |
no title even?!? wow, hope the last registered owner doesn't want it back. _________________ Killing mailboxes since 2009 |
izcain 9sec Club
Posted: Sun Mar 21, 2010 11:10 am Post subject: |
Man I would be gettin that no title issue worked out before I did ANYTHING with that car. _________________
9.17 @ 148 |
IROC-stangs Member
Posted: Sun Mar 21, 2010 11:28 am Post subject: |
flea wrote: | no title even?!? wow, hope the last registered owner doesn't want it back. |
no ok see the car was stolen from us in 98 with the title IN the car and they took EVERYTHING we had in that car and since then it really hasent been driven but we might have another title but not sure where. its under my mothers name though and we just have regular insurance like if there is a fire or something. |
IROC-stangs Member
Posted: Sun Mar 21, 2010 11:31 am Post subject: |
izcain wrote: | Man I would be gettin that no title issue worked out before I did ANYTHING with that car. |
read what i said to the other guy. |
izcain 9sec Club
Posted: Sun Mar 21, 2010 11:54 am Post subject: |
I would but you posted it AFTER I had posted. Kinda hard to read something that hasn't been written yet. _________________
9.17 @ 148 |
IROC-stangs Member
Posted: Sun Mar 21, 2010 12:04 pm Post subject: |
izcain wrote: | I would but you posted it AFTER I had posted. Kinda hard to read something that hasn't been written yet. |
haha you know what i mean im to lazy to type the same thing twice. |
izcain 9sec Club
Posted: Sun Mar 21, 2010 12:52 pm Post subject: |
9.17 @ 148 |
flea Member
Posted: Sun Mar 21, 2010 2:11 pm Post subject: |
IROC-stangs wrote: | flea wrote: | no title even?!? wow, hope the last registered owner doesn't want it back. |
Then you still have a title. It is titled to whoever in your family owns it. You never need to show title, only registration. Title own shows who the legal owner is, even if you don't have that piece of paper in hand, the state still does. Its a good thing to have in case ownership is ever challenged, but other than that its not too big a deal. When you buy a new car it is titled to ABC bank Inc. or whoever the loan is through, however, it is registered to you. I'd be nervous as hell, but thats just my nature.
You initially made me think that the car was bought with no title at all. The only way to fix that is to go back to the last owner (title) and have them release interest in it and sign it over to you, but they could also say 'my car!! I was wondering where i left that.' Then you're SOL. _________________ Killing mailboxes since 2009 |
IROC-stangs Member
Posted: Sun Mar 21, 2010 2:16 pm Post subject: |
flea wrote: | IROC-stangs wrote: | flea wrote: | no title even?!? wow, hope the last registered owner doesn't want it back. |
You initially made me think that the car was bought with no title at all. The only way to fix that is to go back to the last owner (title) and have them release interest in it and sign it over to you, but they could also say 'my car!! I was wondering where i left that.' Then you're SOL. |
ok i think i get what you mean so the vehicle is still in her name proven by whoever does this stuff (govermnet, state hoever) and you dont actually have to have the paper saying so with you. well thats makes the finaly getting legal thing a bit cheaper! ok does anyone know how much tags would be since the old tags expired in 04. |
izcain 9sec Club
Posted: Sun Mar 21, 2010 2:22 pm Post subject: |
One quick "file for a lost title form" from the DMV filled out by the registered owner and the title will arrive in the mail and be good to go. _________________
9.17 @ 148 |
Posted: Sun Mar 21, 2010 10:49 pm Post subject: |
Get the title. The cost for filing is only a few bucks.
If the car was stolen with the title in it, it would be very easy to forge the signature and "buy" the car from your Mom. Then the thieves just pay the tax and they would be sent a nice new title to your car. |
flea Member
Posted: Mon Mar 22, 2010 6:48 am Post subject: |
aaron_sK wrote: | Get the title. The cost for filing is only a few bucks.
. . .And because they don't have the car then they report it stolen, moms get arrested for auto theft, and its a crap shoot whether a judge will figure it all out correctly or not.
This has the potential for real entertainment. _________________ Killing mailboxes since 2009 |
