Posted: Thu Dec 10, 2009 4:28 pm Post subject: Torx headed bolts |
Apparently, hardware stores don't carry them. Neither do parts stores and GM discontinued these bolts. They are for the intake runner to base on an 87 TPI. T-40 head, metric, and 1inch and 2 inches in length. Who knows where I can get some of these bolts? I need 2 one inch bolts and 1 two inch bolt. I tried NAPA, ACE, Lowes, Home Depot, and the GM dealer. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Dec 10, 2009 4:53 pm Post subject: |
Go to Tacoma Screw or Vancouver bolt... and get an Allen head the length and pitch you need. _________________ A redline a day keeps the carbon away! |
Posted: Thu Dec 10, 2009 5:54 pm Post subject: |
| The pitch and diameter are standard. The only unique thing is the head. If you're not picky about that I think they're like an M8x40 or something. |
