Posted: Sat Oct 31, 2009 3:56 pm Post subject: 2.8 Heads rebuilt $100 |
I've got a set of 2.8L heads here. I gave em a valve grind, new seals, and surfaced the fire deck. Glass bead cleaned the heads and valves. Like new!
Buy these so you don't have to send yours out leaving your ride down as long!
Casting # 14054877
$100.
(Machining and seals alone cost over $250) _________________ A redline a day keeps the carbon away! |
HONDASLAYER Member
Posted: Fri Nov 20, 2009 9:36 pm Post subject: |
hey Paul do you have any other 2.8l stuff? _________________
Posted: Sat Nov 21, 2009 11:44 am Post subject: |
Think this is about it. I might have 2.8L v6 Rad.
I have a V6 T5 I could whip together.
What are you looking for exactly!?
You know you need these heads! _________________ A redline a day keeps the carbon away! |
HONDASLAYER Member
Posted: Sat Nov 21, 2009 4:20 pm Post subject: |
almost anything that would improve the drivability. my 2.8 runs like a peice of $#it. _________________
Posted: Sat Nov 21, 2009 4:24 pm Post subject: |
lol, new heads aren't going to fix your car, unless your problem is that it gives the Chevy salute, or has a bad valve or something.
That said, you know do need new heads, and these are not the droids you're looking for... |
Posted: Sat Nov 21, 2009 5:07 pm Post subject: |
What 2.8 do you have? Thought you were rolling a rodge? _________________ A redline a day keeps the carbon away! |
Posted: Sun Nov 22, 2009 11:01 am Post subject: |
I went over there yesterday to pick up seats, and ended up with only the slides.
I think he said it was an 84 what looks like a Cherokee. It has the 2bbl 2.8 GM motor in it. The other was too wide for trails  _________________ 92 Camaro
Posted: Sun Nov 22, 2009 11:26 am Post subject: |
| Al Hasse wrote: | | what looks like a Cherokee. |
Well there's your problem right there! |
Posted: Sun Nov 22, 2009 12:00 pm Post subject: |
| Al Hasse wrote: | I went over there yesterday to pick up seats, and ended up with only the slides.
I think he said it was an 84 what looks like a Cherokee. It has the 2bbl 2.8 GM motor in it. The other was too wide for trails  |
If that's the case, what'd you want with 4.3L stuff? Might as well swap a v8 in.
The carbed 2.8L motors suck. Best thing you can do is swap a camaro FI long block in or swap heads and cam and rebuild the carb. Eliminate most of the vacuum lines.
I did that to an '84 Jimmy... thing ran BETTER and Stronger than my 4.3L 89 Jimmy.
Oh and if the Cheeko has an automatic, there's half you're problem! They're too gutless to run an Auto IMHO. _________________ A redline a day keeps the carbon away! |
HONDASLAYER Member
Posted: Mon Nov 23, 2009 3:31 pm Post subject: |
ya it's an auto with 4.56 gears. I don't know why i asked for 4.3 stuff. When this engine goes i think i wanna drop in a 3.4 if i drop in a v8 i'll have to get all new drive lines, tranny, tc and stuff. Rightknow it's got the "Death Wobbles" so it's in the garage untill i can get that fixed and then it will be my dd. _________________
Posted: Mon Nov 23, 2009 4:15 pm Post subject: |
Jeep + Death Wobble = Bad Toe Alignment. _________________ A redline a day keeps the carbon away! |
HONDASLAYER Member
Posted: Mon Nov 23, 2009 4:18 pm Post subject: |
ya i got that done along with a new track bar, wheels and steering stabalizer. Now i've just got to get new shocks cause the ones on there now are dead. I've gone through this before on my old jeep. _________________
