Posted: Thu Oct 08, 2009 3:17 pm Post subject: HELP!!!!! Intake to head prob |
So evidently these heads are milled, and now my bolt holes from intake to head arnt matching.
So what options do I have? I have not had to deal with this before as this is only the 3rd time I have had a motor down this far. And then, it was just replacing gaskets and putting back together. Not having to deal with milled stuff. |
Posted: Thu Oct 08, 2009 4:10 pm Post subject: |
is the problem the physical gap between the mating surfaces of the intake and head, or just the alignment of the holes?
if its just the alignment of the holes, you could elongate them with a drill or a file, as long as they're torqued to spec and washers are used, they should seal okay. _________________
Posted: Thu Oct 08, 2009 4:32 pm Post subject: |
It is mating surfaces as well.
Starting new thread. Dewey can delete this one if he wishes. |
