		| What should I do with my valve covers? |
			  | Leave Silver |  | 28% | [ 2 ] |
			  | Paint Black |  | 57% | [ 4 ] |
			  | Other (explain) |  | 14% | [ 1 ] |  |
		| Total Votes : 7 |
		| Author | Message |
		| 91RSVert Member
 1991  Chevrolet  Camaro RS
				|  Posted: Sat Oct 03, 2009 10:18 am    Post subject: Under hood opinion (paint) |   |
				| So under my hood is red. AC delete (box on wall is black)
 Polished TPI runners and plenium.
 I have corvette valve covers painted silver.  I though that would look good with my polished runners etc.  It just doesnt match.  So while I am sticking alumn heads on, with all this.  I'm thinking thats just to much silver n bling.
 Think I should paint the valve covers flat black?  Leave silver?
		| Back to top |  |
				|  Posted: Sat Oct 03, 2009 10:47 am    Post subject: |   |
				| Lets see some pictures.
 If you polished the plenum and runners you need polished valve covers IMHO.
		| Back to top |  |
		| 91RSVert Member
				|  Posted: Sat Oct 03, 2009 5:50 pm    Post subject: |   |
				| before I took it apart today.
 I have read that polishing the corvette vc's dont look good as they turn a brownish tent from the oil being absorbed on the inside.
  [/img] |  |
		| Back to top |  |
				|  Posted: Sat Oct 03, 2009 5:56 pm    Post subject: |   |
				| Think I might try some Semi black.
 Flat looks great but with say the dual snorkel and such the semi gloss would look better. Plus, some gloss is way easier to clean.
 Just my .02! Good luck man
		| Back to top |  |
		| 91RSVert Member
				|  Posted: Mon Oct 05, 2009 5:02 pm    Post subject: |   |
				| dunno if this is gonna work......
 can anyone tell me anything worth while on these pistons?
 heads were on sat night.  I spent most of sunday trying to get rockers, then finding I could use mine.  Porting the intake, installing new injectors, finding some pipe fittings, and tending to some drunk neighbors fighting.
 Tonight I still worked on porting the intake.  I almost have that done.
		| Back to top |  |
		| iansane Member
 1991  Pontiac  Trans Am
				|  Posted: Mon Oct 05, 2009 5:34 pm    Post subject: |   |
				|  	  | Twilightoptics wrote: |  	  | Think I might try some Semi black. |
 Werd. And actually I'd probably run the TPI powdered gunmetal or something similar.
		| Back to top |  |
				|  Posted: Mon Oct 05, 2009 6:04 pm    Post subject: |   |
				| Those are nasty smogger dished pistons.
 Think they have something rediculous like 20cc dish.
 Makes for shitty compression. I'd definitely be using the steel shim rubber coated gasket with copper coat.
 If not especially, you're gonna be like 8.5:1
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Mon Oct 05, 2009 6:19 pm    Post subject: |   |
				| Paint black. Drink beer.
 BTW, while I was moving (again) I found that V6 injector harness you were asking about. You still want it?
		| Back to top |  |
		| iansane Member
				|  Posted: Mon Oct 05, 2009 6:21 pm    Post subject: |   |
				|  	  | Twilightoptics wrote: |  	  | Those are nasty smogger dished pistons.
 So you're saying it's a great candidate for a turbo?
		| Back to top |  |
		| Outlaw28 Member
 1984  Chevrolet  Camaro Z/28
				|  Posted: Mon Oct 05, 2009 6:34 pm    Post subject: |   |
				| i think the semi black would look good...but i say be different paint them the same color red as the exterior of car...i think that would look really good with the valve covers red...it will make them stand out |  |
		| Back to top |  |
				|  Posted: Mon Oct 05, 2009 7:04 pm    Post subject: |   |
				|  	  | iansane wrote: |  	  |  	  | Twilightoptics wrote: |  	  | Those are nasty smogger dished pistons.
 NOT WITH CAST PISTONS ITS NOT!!!!
		| Back to top |  |
		| 91RSVert Member
				|  Posted: Tue Oct 06, 2009 2:37 am    Post subject: |   |
				| So with 113 heads .041 steel gasket
 and them pistons.
 What do you think it would be?  I was told this was a gm crate motor.  I thought with my old setup, it would have 9.0:1
 And turboing the car has been talked about
		| Back to top |  |
		| 91RSVert Member
				|  Posted: Tue Oct 06, 2009 4:55 am    Post subject: |   |
				| ok, online calculator
 http://www.angelfire.com/fl/procrastination/motor.html
 4.0 bore
 3.48 stroke
 8
 58cc Is this correct for 113's?
 -20cc
 .041 gasket
 gives me 9.29.   IMO, not bad for a street driver and runs 87/88oct gas.
 :edit:  I went from 65cc heads and .039 gasket.  So I should be getting more compression then I had before.
		| Back to top |  |
				|  Posted: Tue Oct 06, 2009 6:47 am    Post subject: |   |
				| Composite VS Shim _________________
		| Back to top |  |
