Kage87Z Member
1969 Chevrolet Camaro
Posted: Thu Sep 17, 2009 11:34 am Post subject: OK.... which brake line goes where out of the prop valve? |
So, there's 3 lines coming out of the proportioning block or valve... 2 lines are smaller, one is bigger.
Are the two smaller lines to the front (even though they're both in the rear of the block/valve) with the bigger line going to the rear brakes?
Now, the first picture shows the line lock solenoid plumbed into the brake system. But the more I thought about it, the more I was sure that the larger diameter line must go to the rear brakes instead of one of the fronts.
On the second picture, the lines going into the top are, of course, coming out of the master cylinder.
Over to the far right just above the plastic wrap is the thicker line I was talking about; I have cut the fitting off using a tube cutter so all that's visible is an unflared steel line.
The 2 remaining lines, which are smaller in diameter once you pull the wire wrap off them, are still in the valve/block, one on the angled surface just to the right of the large, black exhaust fitting, and the other line is directly below that.
Can someone verify that for me, please? _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Kage87Z Member
Posted: Thu Sep 17, 2009 6:17 pm Post subject: |
Not sure I get what you're puttin' out there.
Did you figure it out from my picture, or need more explaination? Just to make sure you've got the info you need.  _________________ A redline a day keeps the carbon away! |
Kage87Z Member
Posted: Thu Sep 17, 2009 10:21 pm Post subject: |
I figured it out from your pic.
The smaller lines are for the front; the bigger line for the rear.
I put it in the same way I did the 69, but obviously, the fittings and locations changed just the tiniest bit over the intervening 18 years or so.
I've got the cutter, bender and flare tools so it shouldn't be that big a hassle, but it is a PITA making that happen in the engine compartment with the engine in there.
Thanks for the pic... and thanks for responding before I tried the line lock with the wrong plumbing hooked up.
I get the feeling THAT would have been just the tiniest bit awkward. _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
