Posted: Fri Sep 18, 2009 7:21 pm Post subject: Last call for free junk |
I'm moving (again), and this stuff will go to the dump or recyclers soon if not claimed:
Complete V6 intake off of a 3.1L. I have upper and lower plenums, as well as the manifold base.
Throttle body for 3.1L. Has all sensors. Don't know if they work.
Injector harness for 3.1 car. Has different plug on the harness end than the 2.8 cars for some stupid reason.
ECM from 3.1 car. Don't remember the number.
Fuel rail for 2.8 car. Injectors are clogged or bad or something is wrong with the regulator, I don't know. Replacement was cheaper than diagnosis.
Front lowering springs. Some old-school brand, 'Suspension Technologies' or something like that. Got around 15K on them AFAIK.
All free. All for pickup in Spanaway, WA.
Come on guys, save this junk from being crushed and made into Kia's! |
91camaro_rs Member
Posted: Fri Sep 18, 2009 8:55 pm Post subject: |
| ill take those lowering springs please, ill be over in spanaway tomorrow can i pick them up then? |
Posted: Fri Sep 18, 2009 11:59 pm Post subject: |
| That works. Call first. I'll be around somewhere. |
Posted: Sat Sep 19, 2009 5:35 am Post subject: |
The ecm is a 7730, which is the same as a TPI, just needs a prom.
Does the injector harness have numbers on them? 1,2,3,etc? |
Posted: Sat Sep 19, 2009 7:42 am Post subject: |
| 91RSVert wrote: | | Does the injector harness have numbers on them? 1,2,3,etc? |
I don't think so. I didn't mark it before I pulled it because it basically only goes on one way. |
Posted: Sat Sep 19, 2009 9:54 am Post subject: |
| aaron_sK wrote: | | 91RSVert wrote: | | Does the injector harness have numbers on them? 1,2,3,etc? |
Doesn't matter anyway. From what I've learned, the injectors are batch fired. We didn't label them when we replaced my 3.1 a couple of years ago. _________________ 92 Camaro
Posted: Sat Sep 19, 2009 9:59 am Post subject: |
left side and right side. _________________ A redline a day keeps the carbon away! |
Posted: Sat Sep 19, 2009 1:51 pm Post subject: |
| I was wanting to know so I could build a harness out of it. Not use it as it is. |
