cameron7710 Member
Posted: Sat Sep 12, 2009 9:41 pm Post subject: tune up problem |
ok well i just replace the cap,rotor and spark plugs on the camaro and it runs great and feals like it has twice the power but there is one problem now when i fire it up at first it runs like shizzle misfiring badly and trying to stall but once it stops that after a minute it runs great but the engine light comes on. any got any ideas what could cause this? _________________
Posted: Sat Sep 12, 2009 10:04 pm Post subject: |
| Do you know how to jump the ALDL to pull codes? |
cameron7710 Member
Posted: Sat Sep 12, 2009 10:23 pm Post subject: |
| aaron_sK wrote: | | Do you know how to jump the ALDL to pull codes? | i was told how to but cant find where to do it at _________________
Posted: Sun Sep 13, 2009 6:15 am Post subject: |
take a paper clip and jump the two top right pins on your diagnostics port.
Then turn the key to "run" and count your check engine light blinks.
will always start with code 12 IIRC, then go onto the real codes. |
Posted: Sun Sep 13, 2009 8:01 am Post subject: |
| 91RSVert wrote: | take a paper clip and jump the two top right pins on your diagnostics port.
It will flash each code 3 times, starting with code 12, then end with code 12. 12 says the ECM is working. Everything that may show between the first and second sets of code 12 is a trouble code. _________________ 92 Camaro
Posted: Sun Sep 13, 2009 9:40 am Post subject: |
Actually, code 12 means the distributor is not working, but yeah.
Get some paper and a pen, there might be a few codes. After you pull all the codes, unhook the battery for a minute, then hook it back up, start the car, and wait for the SES. Then pull codes again. That makes sure you have a current set of codes, with no history. |
kurfbird Member
Posted: Sun Sep 13, 2009 12:15 pm Post subject: Timing |
Did you check the timing after replacing everything _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Sun Sep 13, 2009 6:52 pm Post subject: |
| aaron_sK wrote: | Actually, code 12 means the distributor is not working, but yeah.
Actually code 12 flashes every time you run the SES light diagnostic. :O) _________________ A redline a day keeps the carbon away! |
cameron7710 Member
Posted: Sun Sep 13, 2009 7:57 pm Post subject: |
ok got it all figured out got codes 32 and 33 so i was checking that out and found some unpluged vacum line on the back of the tb so got that all done aand now it runs better then ever. then i figured what the rattling sound that i thought was the water pump is turns out the belt tensioner pulley bearing is bad and the smog pump is making some noise. so if anyone has a working noise free serpentine smog pump around that would be cool to get all them rattles gone _________________
Posted: Sun Sep 13, 2009 9:45 pm Post subject: |
| Those smog pumps are notorious for being noisy. The one on my V6 is quite noisy, been that way for years, works fine though. |
