91camaro_rs Member
Posted: Tue Sep 29, 2009 6:16 pm Post subject: door hinges |
so yesterday i was workin on my car and...well i not gonna go into detail hahah anyway i ended up messin the hinge up, so the door kinda sags now and makes it hard to open, how do i go about tightening the hinge?? _________________
popballz Member
Posted: Tue Sep 29, 2009 9:10 pm Post subject: |
three bolts on top from hinge to body--13mm
1 bolt on bottom outside-i think its a 13mm too, then two bolts on inside--15mm
hinge pin is like $7, for the bottom
top pins are like $70.
did that help at all? _________________ -Donald
Posted: Tue Sep 29, 2009 9:13 pm Post subject: |
Depends on what part of it you messed up. Could be a bent bin, bad bushing, oblong-ed pin hole, bent bracket. Compare the two sides while you open and close each door.
BTW, you forget to close the door before you lowered it off the jack?  |
91camaro_rs Member
Posted: Tue Sep 29, 2009 9:44 pm Post subject: |
| Quote: | | you forget to close the door before you lowered it off the jack? |
way worse than that .....way worse
| Quote: | | did that help at all? | and i think its a bent pin...how bout we meet up and you can take a look at it, idk what i am lookin at lol _________________
Posted: Tue Sep 29, 2009 10:32 pm Post subject: |
| Call me around 5:30/6:00 tomorrow night. I'll be in Tacoma picking up parts after I get off work. |
Posted: Wed Sep 30, 2009 2:05 am Post subject: |
You backed up without looking behind you with the door open and the door caught a pole, eh? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Sep 30, 2009 2:38 am Post subject: |
I just got done redoing mine. If you want to send me pics, I'll try to help you.
15mm on the bottom inside.
13mm for the bottom front.
13mm on the tops.
Wratchet wrench is your friend on 13mm. _________________ 2008 GMC Z71
Posted: Wed Sep 30, 2009 5:55 am Post subject: |
BTW, now I can laugh at you thirdgen guys and your expensive hinges. I just got done doing the doors on the S10. $37 with tax out the door for a complete set (four) of the good NAPA pins.
How many TDS pins can you buy for $37?  |
Posted: Wed Sep 30, 2009 6:30 am Post subject: |
| aaron_sK wrote: | How many TDS pins can you buy for $37?  |
1/4" of a kit? If it helps I have the TDS greasable pin kit in stock.  _________________
91camaro_rs Member
Posted: Wed Sep 30, 2009 9:12 am Post subject: |
well i guess it helps explain the problem if i say what happened ....
i was backing it up onto ramps and lets just say i went up and over
so i have no idea what part of the hinge broke but its hard as hell to open my door _________________
Posted: Wed Sep 30, 2009 12:34 pm Post subject: |
Is the door itself damaged any? It may be a bent door.
Otherwise I think they may have just got knocked out of adjustment. Post some pics of the hinges so we can see if they got damaged. Also, post pic of door closed so we can see if any of the gaps are off.
PS. Dont feel bad, I was driving off a stack of boards(car was to low for jack), one of them flipped up and folded the front half of my fender and front air damn. |
popballz Member
Posted: Wed Sep 30, 2009 2:11 pm Post subject: |
And that is why I am scared of those ramps
It takes me a few minutes to get on then since I barly push the gas and keep rollong backward. _________________ -Donald
Posted: Wed Sep 30, 2009 6:17 pm Post subject: |
Pffft. Do ramps with a clutch and a TPI engine with enough torque to fling the suckers, then you can complain.  |
Posted: Thu Oct 01, 2009 6:05 am Post subject: |
| aaron_sK wrote: | Pffft. Do ramps with a clutch and a TPI engine with enough torque to fling the suckers, then you can complain.  |
been there, done that too.
Or on a slick garage floor and the ramps either slide, or your tires spin. |
Posted: Thu Oct 01, 2009 6:26 am Post subject: |
What kind of ramps are you guys using that can fit underneath either end of your thirdgens? I've never found a set that wasn't $150+ or way too tall. _________________
Posted: Thu Oct 01, 2009 6:43 am Post subject: |
My v6 when I first got it, would fit on some basic ramps. Wouldnt after I lowered it.
Never tried this one as I lowered it just a few weeks after getting it. |
Posted: Thu Oct 01, 2009 7:09 am Post subject: |
| iansane wrote: | | What kind of ramps are you guys using that can fit underneath either end of your thirdgens? I've never found a set that wasn't $150+ or way too tall. |
Built some out of two 10ft. 2x6's. Still got 'em, should probably do something with them now that I don't own a car that low.  |
TurdGen1989 Member
Posted: Thu Oct 01, 2009 9:52 am Post subject: |
i always just put a little 2x4 or something in front of it and it skips by just barely _________________ Phil.
GMC High Sierra
91camaro_rs Member
Posted: Thu Oct 01, 2009 10:08 am Post subject: |
| 91RSVert wrote: | | aaron_sK wrote: | Pffft. Do ramps with a clutch and a TPI engine with enough torque to fling the suckers, then you can complain.  |
that was exactly what happened, tires spun and the ramps slid right under the car
ill get some pics up as soon as i can _________________
Posted: Fri Oct 02, 2009 12:03 am Post subject: |
I used to be able to use those ramps when I was at stock height. Barely cleared the front lip. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
