Posted: Tue Aug 11, 2009 8:49 am Post subject: Q on vette TPI |
Did the vettes ever go to a map system with no cold start injector?
Thinking of going to the vette heads, vette base intake, and plumbing an EGR in off my y-pipe. |
Posted: Tue Aug 11, 2009 8:50 am Post subject: |
What does it matter. If you use your computer you're fine. All the sensors hook up. Really don't think you'll gain much from the heads, and the base from what I understand is identical as far as flow characteristics are concerned.
You'd be better off with Vortec heads and the Vortec base IMHO if you're staying TPI.
Otherwise ditch the TPI and go HSR and not have the wall. _________________ A redline a day keeps the carbon away! |
Posted: Tue Aug 11, 2009 9:37 am Post subject: |
I dont want to have to plug a cold start injector hole and possibly have a spot for another vac leak.
My heads are the 810 swirl heads. I have ALOT to gain by going vette heads.
The vette base is different because of the EGR hole.
Price is my main concern, I have a cracked head, needs replaced.
1. If I go vortec they cost more. Then I have to buy the over price special base.
2. I go vette, they bolt right in. I dont HAVE to swap lower base, but would like to.
The "wall" you speak of, I have not found on my car. Because I have no need to rev it that high. |
Posted: Tue Aug 11, 2009 10:09 am Post subject: |
Better do some research on vette chamber sizes. Your swirls I think are 58cc. If the vette heads are bigger you'll lose quite a bit of compression.
I know the base is different. I wrote | Quote: | the base from what I understand is identical as far as flow characteristics are concerned.
Vette heads were made for 350s, not 305s. You still have the 305?
Plugging the hole is no big deal. Hell, weld the thing shut.
I think I remember Joe putting Vette heads on his 305 and making way less power than a stock 305 TPI.
I didn't know ANY TPI motor came with swirl ports. Thought that was TBI and crappier specific. _________________ A redline a day keeps the carbon away! |
Posted: Tue Aug 11, 2009 10:42 am Post subject: |
I have a crate 350 for a truck. I made it a TPI.
I dont have the ability to weld alumn YET. |
Posted: Wed Aug 12, 2009 6:00 am Post subject: |
oh, so the egr is still under the intake. Crap.
But I guess I could mount the EGR outside, and just make a "jumper pipe" in the intake.  |
Posted: Wed Aug 12, 2009 9:46 am Post subject: |
| 91RSVert wrote: | oh, so the egr is still under the intake. Crap.
Didn't you just say you were worried about vacuum leaks?! _________________ A redline a day keeps the carbon away! |
Posted: Wed Aug 12, 2009 10:44 am Post subject: |
Yea, but I also didnt realize the CSI was in the runners.
You likely dont know, I dont have a normal wiring system, and dont use the UFO egr. I am running a digital egr. |
