batcave Member
Posted: Sat Jun 27, 2009 5:16 pm Post subject: check eng light |
| ran scan on my 1988 formula a code 34 comes up changed maf sensor problem is still there could i have a short in one of my wires going to my maf any good shops in vancouver to take this car |
kurfbird Member
Posted: Sat Jun 27, 2009 7:18 pm Post subject: DId you reset the ECM |
Did you reset the ecm and see if the code comes back. Discoenct the battery for 30 seconds _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
batcave Member
Posted: Sat Jun 27, 2009 8:57 pm Post subject: |
| disconected the battery code still comes up changed maf sensor same prob car had 2 wires that were soldered together years ago on maf car runs fine for the first 3 starts then the light turns on again |
Posted: Sun Jun 28, 2009 8:45 am Post subject: |
Verify the wires are good and soldered together in the right order.
Then replace the MAF power and burnoff relays. _________________ A redline a day keeps the carbon away! |
batcave Member
Posted: Sun Jun 28, 2009 10:54 am Post subject: |
| the 2 burnoff relays are they the ones in the back by the fire wall |
Posted: Sun Jun 28, 2009 12:12 pm Post subject: |
One is the burn off, one is the maf power, one is fuel pump, sometimes there is a 4th one depending on year.
Fuel pump should be one with a green wire/white stripe. _________________ A redline a day keeps the carbon away! |
batcave Member
Posted: Sun Jun 28, 2009 12:51 pm Post subject: |
| thanks for the help im trying to get this car out of the garage so i can finally drive it instead of letting it sit |
