emergency flashers
91camaro_rs
PostPosted: Tue Jun 16, 2009 9:04 pm    Post subject: emergency flashers Reply with quote
ok so my hazards dont work, i made a post about this before, and you guys said to get the new turn signal/ hazard relay (the 2 pin thing) and i just got a new one and it didnt work. so what else would be causing my hazards to not work?
PostPosted: Tue Jun 16, 2009 9:19 pm    Post subject: Reply with quote
Have you checked the 20AMP ACC fuse?
'88 FORMULA
91camaro_rs
PostPosted: Wed Jun 17, 2009 12:48 am    Post subject: Reply with quote
i havent checked it yet but i was lookin under the dash earlier and i noticed that i tried to switch out the turn signal thing which is on the left side under the dash and there is another which i assume to be the hazard relay on the right side of the dash, ill try checkin both things tomorrow
