ignition cylinder
PostPosted: Fri Jun 19, 2009 11:53 am    Post subject: ignition cylinder Reply with quote
how do you pull out the ignition cylinder? Just need to swap mine out before i get completely locked out.
I have a haynes book but it is predictably useless.
PostPosted: Fri Jun 19, 2009 12:19 pm    Post subject: Reply with quote
We just had a post about it.
http://cascadecrew.org/phpBB2/viewtopic.php?t=5956&start=0
PostPosted: Fri Jun 19, 2009 2:09 pm    Post subject: Reply with quote
we did??
Hmm figures.
PostPosted: Fri Jun 19, 2009 2:20 pm    Post subject: Reply with quote
ok i read through that thread, but I do have an airbag, one besides my mother in law that is. I know I need to disconnect the battery etc. but what do i need to do to pull the wheel with that airbag in the way. I told it to get the heck outta the way but it doesn't listen any better than the mother in law.
PostPosted: Fri Jun 19, 2009 2:34 pm    Post subject: Reply with quote
Disconnect battery and pull airbag fuse. Then get at the screws behind the wheel to pull the air bag out. Then disconnect the wiring. The rest is as follows.
Do bagged thirdgens have clock springs?
PostPosted: Fri Jun 19, 2009 5:15 pm    Post subject: Reply with quote
Ok which fuse is the airbag? I see one that say SIR a 10 amp is that the guy? I really don't want it to blow up in my face.Battery is disconnected, but as I was removing the screws I saw it moving normal I know,but it skeeter me.it would really ruin my night to blow the airbag
PostPosted: Fri Jun 19, 2009 5:20 pm    Post subject: Reply with quote
It's actually pretty hard to set them off. SIR should be Safety Inflatible Restraint. So yes.
And with the battery disco, it shoudn't blow up. I don't even mess with the fuse, just the battery. There has to be an electrical charge to trigger the bag.
PostPosted: Fri Jun 19, 2009 5:21 pm    Post subject: Reply with quote
Ok here goes nothing then
PostPosted: Fri Jun 19, 2009 7:44 pm    Post subject: Reply with quote
Ok how do you bypass VATS.and please tell me it's in the steering column
PostPosted: Fri Jun 19, 2009 7:57 pm    Post subject: Reply with quote
It can be done in the column, I suppose. The easiest way is under the dash.
Post #5 has a good how to.
http://www.thirdgen.org/techboard/electronics/515925-how-disable-vats.html
PostPosted: Fri Jun 19, 2009 8:25 pm    Post subject: Reply with quote
Guess what I just did
Wrong.
You know that little bitty lock ring that goes to hold the lock plate in, well I sort of sent flying across the old yard. And here I was that guy that was happy. Where am I gonna find another one of those little guys I kind of need it it looked important.
PostPosted: Fri Jun 19, 2009 8:32 pm    Post subject: Reply with quote
get a big magnet, and go find it!
PostPosted: Fri Jun 19, 2009 8:38 pm    Post subject: Reply with quote
im gonna find a big hardware store and find the retaining ring section
d00012
PostPosted: Fri Jun 19, 2009 10:01 pm    Post subject: Reply with quote
Haha, that's why I have a giant magnet on a stick. I've lost so many metal stuff in the yard and in the driveway, that my dad made me this "metal detector" when I was a kid and to use it to find any thing that was lost.
Laughing
PostPosted: Fri Jun 19, 2009 10:52 pm    Post subject: Reply with quote
Well bring your "metal detector" over LOL
PostPosted: Sat Jun 20, 2009 7:37 am    Post subject: Reply with quote
Double post.
Well got it going thanks for the hand. Didn't bypass vats at all just bought a chipped key it works in the new cylinder
