GREG DAVIDSON Member
Posted: Wed Mar 11, 2009 5:27 pm Post subject: tune up question |
i was just wondering if theres a real diff in ignition peices like plug wires cap rotor and ignition coil for the 350 vs the 305 everyone had the 350 stuff but the stuff i want for my 305 is special order im wanting to upgrade my ignition setup but i dont want to burn out another piston if the 350 stuff has a hotter spark _________________
Posted: Wed Mar 11, 2009 6:13 pm Post subject: |
There are significant differences in brand but not from 305 to 350. Typically the hotter the spark then better. That's why many of us have after mArket coils which produce more voltage. When you have more voltage you need better wires to handle that higher voltage. _________________ A redline a day keeps the carbon away! |
Posted: Wed Mar 11, 2009 6:32 pm Post subject: |
| ok cool so if i get 350 stuff i'll be perfectly fine then |
Posted: Wed Mar 11, 2009 6:35 pm Post subject: |
Yup _________________ A redline a day keeps the carbon away! |
Posted: Wed Mar 11, 2009 7:19 pm Post subject: |
I'd be disturbed if they were telling you there was a difference... _________________
Posted: Wed Mar 11, 2009 7:26 pm Post subject: |
| they try to i just wanted to make shure i trust you guys more on here than any random parts guy here in salem ... lets just say i havnt met to many bright ones lol |
fiveoformula Member
Posted: Wed Mar 11, 2009 8:50 pm Post subject: |
They should be the same... Cap & Rotor, no difference. R45TS AC delcos, or 26 Autolite, shouldn't be a different heat range from 305-350....
For wires Id get some MSD's or Taylors. |
Posted: Thu Mar 12, 2009 1:14 am Post subject: |
| these are the wires im looking at i know its kinda hard to read but they are an msd brand i've been doing alot of comparison shopping |
Posted: Thu Mar 12, 2009 2:16 am Post subject: |
MSD wires suck. Seen 3 die quick including one of my own.
Delco 45s and Autolite 26's seem a little hot to me. I run autolite 25's they are a colder plug. When I get my normal computer back tomorrow I'll give you a link that explains spark plug heat ranges. _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 12, 2009 2:19 am Post subject: |
| im planning on using ngk's for plugs |
Posted: Thu Mar 12, 2009 8:56 am Post subject: |
| Twilightoptics wrote: | | MSD wires suck. |
I second this. I had the 8mm cut-to-fit MSDs on my bird for a little over a year and I went to change them to Taylors right before I wrecked it and 3 of the boots to the plug pulled right out of the wire. And those are on the factory installed side! _________________
Posted: Thu Mar 12, 2009 10:02 am Post subject: |
No MSD. Get Taylor cut-to-fit wires off of Summit. Like $60 for the 8-cyl set. If you don't have a good plug wire crimper, Taylor sells a decent one, you will need something better than the usual universal crimpers. |
Posted: Thu Mar 12, 2009 10:19 am Post subject: |
Summit brand wires are taylor and they are half the price! _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 12, 2009 10:22 am Post subject: |
| Twilightoptics wrote: | | Summit brand wires are taylor and they are half the price! |
Sweet! I always thought Summit brand was MSD. That'll save some bucks.  |
Posted: Thu Mar 12, 2009 11:15 am Post subject: |
| aaron_sK wrote: | No MSD. Get Taylor cut-to-fit wires off of Summit. Like $60 for the 8-cyl set. If you don't have a good plug wire crimper, Taylor sells a decent one, you will need something better than the usual universal crimpers. |
My Taylor LSx wires were $60 for the set. And they're only like ten inches long each! |
Posted: Thu Mar 12, 2009 11:23 am Post subject: |
| so whats everyones opinion on cap rotor coil combo's ? |
Posted: Thu Mar 12, 2009 11:48 am Post subject: |
| iansane wrote: | | aaron_sK wrote: | No MSD. Get Taylor cut-to-fit wires off of Summit. Like $60 for the 8-cyl set. If you don't have a good plug wire crimper, Taylor sells a decent one, you will need something better than the usual universal crimpers. |
Haha, that's $9/ft! (6.66' @$60) They must be capitalizing on the fact that it's LSx stuff. Bastards  |
Posted: Thu Mar 12, 2009 12:04 pm Post subject: |
Msd's cap and rotor have done me well. Any with the brass terminals will do _________________ A redline a day keeps the carbon away! |
| Damn Ian, at that price, you could have bought a full set, and put the coils on the firewall or something. |
Posted: Thu Mar 12, 2009 1:08 pm Post subject: |
| aaron_sK wrote: | | Damn Ian, at that price, you could have bought a full set, and put the coils on the firewall or something. |
I haven't found a relo kit that looks good. Sucks. |
