Red Bird Member
1991 Pontiac Firebird
Posted: Thu Apr 02, 2009 8:14 pm Post subject: How to id a chevy engine |
Hey guys, i just picked up an 85 trans am 5spd with no motor, and am going to check out a 350 to swap in on sunday. What numbers should i pull off of the motor to i.d. what size it is what year it was made etc... where those numbers would be, and is there a website that decodes the numbers? thx in advance _________________ 1991 Firebird L03 T-5 |
Posted: Thu Apr 02, 2009 8:45 pm Post subject: |
Casting number on the driver side of the block near the Bellhousing mounting flange.
You'll want something that I.D's as either a Large Journal 327 or 350 Block. (both will have a 4.00" bore)
http://www.nastyz28.com/sbchevy/sblock.php
Moretec works too. google it. _________________
Red Bird Member
Posted: Thu Apr 02, 2009 9:55 pm Post subject: |
thx i appreciate it. _________________ 1991 Firebird L03 T-5 |
Posted: Fri Apr 03, 2009 6:49 am Post subject: |
www.mortec.com
Is fantastic. _________________ A redline a day keeps the carbon away! |
Posted: Sat Apr 04, 2009 2:26 pm Post subject: |
Now how is one supposed to ID a TPI engine while it's still in the car? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
izcain 9sec Club
Posted: Sat Apr 04, 2009 4:42 pm Post subject: |
A light and a mirror have always worked really well for me!  _________________
9.17 @ 148 |
