grimreaper88 New Member
Joined: 26 Feb 2009 Posts: 5 Location: clallam bay WA
Posted: Wed Mar 11, 2009 9:24 pm Post subject: i need a starter |
i need a starter for my 305. without a starter i can't even tell if the engine turns over. i have 3 other starters (that i don't know where they are) but i have no idea if they will fit or if they even work. so if anyone has a spare starter i could really use it. _________________ 88 rs camaro |
kurfbird Member
Posted: Thu Mar 12, 2009 8:21 pm Post subject: 305 starter |
I ahve a good starter 305 / 350 from a 92 firebird. 20.00 shipped to you _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
izcain 9sec Club
Posted: Fri Mar 13, 2009 4:39 pm Post subject: |
They make 4 varients of the small block starter. The cross bolt with either smaller 153 tooth flexplate or the 168 tooth larger flexplate. along with the straight bolt pattern with either 153 or 168 tooth flywheels. Make sure you get the correct one for your app. _________________
9.17 @ 148 |
