coolant system
PostPosted: Mon Mar 23, 2009 1:40 pm    Post subject: coolant system Reply with quote
ok any ideas got the red one going AGAIN Rolling Eyes not the temp gauge and the fan doesnt work they both worked before the swap i put a new coolant temp sensor in to but no dice again any ideas helpfull guys thanks
PostPosted: Mon Mar 23, 2009 5:36 pm    Post subject: Reply with quote
This a single fan setup or dual? TPI still?
If so one sensor in the cylinder head will be for the temp gauge and one on the other cylinder head will be for the fan. Each are single wire. Make sure you've got the right sensor hooked to the right wire. They wont work backwards because one is variable (temp gauge) and one is a switch (fans).
On the intake there are two sensors on the front, the big square plug one is for the cold start injector (don't know the year off hand so I can't verify you have it or not) the other sensor is oval plugged and for the ECM temp.
Hope this helps.
PostPosted: Mon Mar 23, 2009 5:41 pm    Post subject: Reply with quote
yep single fan tbi still and its an 89 engine in a 90 body same diff though , guess i have to do some wire chasing
PostPosted: Mon Mar 23, 2009 5:42 pm    Post subject: Reply with quote
When you swapped motors, did you swap the senders and put them in the new motor on the proper head?
PostPosted: Mon Mar 23, 2009 5:54 pm    Post subject: Reply with quote
everything that was on the engine i left on there
PostPosted: Mon Mar 23, 2009 5:55 pm    Post subject: Reply with quote
That could be your problem. Go find that other engine and get the right sending units and put them in the right spot!
PostPosted: Mon Mar 23, 2009 6:20 pm    Post subject: Reply with quote
thanks for the help paul now i know what i need to do lol
