cameron7710 Member
Posted: Sun Nov 09, 2008 9:35 pm Post subject: dashlights |
i just wanted to know if enyone knew how many light bulbs are in a 92 camaro gauge cluster.cause i have so many burnt out that all i can see is if i redline the rpms . but i have been useing this little getto led light thing that plugs into my cigarett lighter and it just looks so bad with the wires every where.and its blue . so its time i get around to fixing that. i keep for geting cause i never really get to driver her at night but i did today and it sucked. _________________
Posted: Sun Nov 09, 2008 9:49 pm Post subject: |
There are about 4 to light the gauges. The rest are for the SES, brake, seat belt, blinkers, high beam and each has its own compartment to keep its light contained. The four to light the gauges shine into the end of a plastic piece like fiber optic to spread the light through the gauges. _________________ 92 Camaro
cameron7710 Member
Posted: Sun Nov 09, 2008 10:00 pm Post subject: |
ok thanks al. oh and i was just thinking about how my sisters bronco has green lights for the gauge and mine r just boring clear lights im thinking maybe it would look better if i throw some green bulbs in there.also im im assuming that theres supposed to be lights in the center which is just a guess cause i have none .but enyone know how many bulbs in there. wow i just noticed how i have like no lights  _________________
Posted: Sun Nov 09, 2008 10:11 pm Post subject: |
| If your gauges don't light up, check your light switch, its dimmer function may be out or just turned all the way down. There's also a fuse for them in the fuse panel, labeled INST LTS or something similar. |
Posted: Sun Nov 09, 2008 10:16 pm Post subject: |
| 'birds come with little orange condoms on all the dash lights to illuminate everything orange-y. I like it. After market gauges sets come with condoms like that in red and green. I'd try those covers before colored bulbs. They're last longer. |
cameron7710 Member
Posted: Sun Nov 09, 2008 10:21 pm Post subject: |
well i have some lights just not really eny that do me eny good like my radio lights work and a bit of my rpm gauge lights up and all them lights like binkers and things work so would that still be the problem if those work. cause the onely lights im not sure work are the lights that tell me if im in park or drive or whatever and my heater control panal but im just guessing there r light in there  _________________
Posted: Sun Nov 09, 2008 10:42 pm Post subject: |
| Sounds to me like 2 or 3 in the instrument panel are out, there is one in the HVAC controls on the far right. IIRC there is no light for gear selection on Camaros, but I could be wrong. |
cameron7710 Member
Posted: Sun Nov 09, 2008 10:56 pm Post subject: |
ya i wasnt sure if there was but that dont really matter caues i know where the are grears without looking _________________
