O2 sensors dying
PostPosted: Mon Nov 10, 2008 10:15 pm    Post subject: O2 sensors dying Reply with quote
What would be killing O2 sensors after less than a thousand miles? I'm on my third sensor since March, and it just started having problems. They never throw a code, but gas mileage drops into the single digit range, and TunerPro shows that they start to have very high readings (750-900mV range) and never drop down to normal range.
I am running a single Bosch sensor in the drivers side header right before the collector gasket. Would I do better to get a heated sensor and relocate it to right before the cat?
PostPosted: Tue Nov 11, 2008 7:28 am    Post subject: Reply with quote
I've had bad luck with Bosch sensors myself.
Location should be fine though.
Water tends to kill them IIRC.
PostPosted: Tue Nov 11, 2008 10:18 am    Post subject: Reply with quote
I kinda figured it might be that after I had such bad issues with Bosch spark plugs. Problem is that's all anybody carries around here. Are NGK or Delco ones any better?
PostPosted: Tue Nov 11, 2008 10:59 am    Post subject: Reply with quote
I had been using a 3 wire heated delco with my LTs and for the wideband an NTK (NGK). Lasted for the year or so I had them in there with no problems.
Bosch are OE for a lot of companies though. Like VW. Although everyone knows VWs are just a little bit off. Laughing
Boostd1
PostPosted: Thu Nov 13, 2008 10:55 am    Post subject: Reply with quote
Bosch sensor's suck...go with a Denso sensor.
2008 Saturn Astra XR | Sold
