factory gm sterio pig tails
PostPosted: Thu Nov 06, 2008 9:43 pm    Post subject: factory gm sterio pig tails Reply with quote
in the process of putting my dash back together on my 89 formula the last owner cut all the wires for the sterio i was wondering if anyone had a spare they dont need been a little wet to hit the local pick a part i just wanna see if i can figure out the wires myself so i dont have to hire someone to put a sterio in my car
PostPosted: Thu Nov 06, 2008 10:09 pm    Post subject: Reply with quote
Can't help with the pigtail, I used to have some drawings with that info on them, but I can't find them any more. I did make a post or two for someone else trying to decipher the wire colors, I'll search and see what I can find. If all else fails, you could always subscribe to All Data and find everything electrical about your car.
EDIT: I found it. If you're looking at the 20 pin connector, this is what I have in my 89.
Pin 1 - GRY - Left Front Speaker (-)
Pin 2 - TAN - Left Front Speaker (+)
Pin 3 - DK GRN - Right Front Speaker (-)
Pin 4 - LT GRN - Right Front Speaker (+)
Pin 5 - BLK - GND
Pin 6 - BRN - Interior Park Lamp Supply Voltage
Pin 7 - GRY - Instrument Panel Lamp Supply Voltage (Dimmer)
Pin 8
Pin 9 - YEL - Fused Output (ACC)
Pin 10 - ORN - Fused Output (BATT)
Pin 11
Pin 12
Pin 13
Pin 14
Pin 15
Pin 16
Pin 17 - LT BLU - Right Rear Speaker (-)
Pin 18 - DK BLU - Right Rear Speaker (+)
Pin 19 - YEL - Left Rear Speaker (-)
Pin 20 - BRN - Left Rear Speaker (+)
The ones I left blank are not used. Hope this helps a bit. You should be able to find the corresponding wires under the dash if your harness is hacked, that's what I had to do. Of the blank ones, pin 16 for the Camaros is used for a VSS input for Speed Controlled Volume, and pin 14 (I think) is used on the Firebirds for steering wheel controls, but I'll have to look that up again.
PostPosted: Thu Nov 06, 2008 10:42 pm    Post subject: Reply with quote
thanks al that is a huge help i looked through both my chilton and my haynes books and either i didnt see it or its not in there thanks
