the T/A is smoking...ALOT
Jason_Culbertson
1982 Pontiac Trans Am
PostPosted: Thu Nov 06, 2008 3:25 am    Post subject: the T/A is smoking...ALOT Reply with quote
ok so the other day i started my car up and pulled it out of the garage so i can wash it, i had a little trouble starting her up but she kicked over. i let her worm up for 10-15 min and smoke EVERY WERE Mad this has been a problem since i got the car but it was just a little when he got her and only when she was first started up. now she smokes all the time so i need help it has to be the head gasket right? or maybe the rings? HELP ME
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Thu Nov 06, 2008 7:40 am    Post subject: Reply with quote
White smoke = head gasket
Blue smoke = engine rebuild
Blue smoke at startup = valve seals
PostPosted: Thu Nov 06, 2008 10:33 am    Post subject: Reply with quote
In addition to Paul's questions: How does the oil look? Low? High? Milkshake? Is the coolant low or bubbly? Have you run a compression test on it yet?
Jason_Culbertson
PostPosted: Thu Nov 06, 2008 10:37 am    Post subject: Reply with quote
[quote="Twilightoptics"]White smoke = head gasket
this is it
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
Jason_Culbertson
PostPosted: Thu Nov 06, 2008 10:39 am    Post subject: Reply with quote
um i bought the car back in april and it has maybe 20 milies on it sence i bought it. he are gunna flush the radiator tomorow and the oil is fine
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
PostPosted: Thu Nov 06, 2008 10:45 am    Post subject: Reply with quote
Don't bother flushing. You're probably gonna have to dump it anyway. Do check to see if it's abnormally low though, as it's most likely getting pulled into a cylinder. Throw a compression tester on there to find out which cylinder is your problem.
Jason_Culbertson
PostPosted: Thu Nov 06, 2008 3:12 pm    Post subject: Reply with quote
ok ill have to check it Saturday, im not at home
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
PostPosted: Thu Nov 06, 2008 3:43 pm    Post subject: Reply with quote
You need to have someone pressureize the coolant system and see if it leaks.
You sure it's not the typical white smoke condensation in the exhaust being burnt off as steam? Look at my sig?
Jason_Culbertson
PostPosted: Fri Nov 07, 2008 7:38 am    Post subject: Reply with quote
nope it did it when it was 90 in the summer too
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
PostPosted: Fri Nov 07, 2008 9:45 am    Post subject: Reply with quote
Take the heads off. Get new gaskets. Have the heads surfaced, maybe even valve grind since they're out.
Jason_Culbertson
PostPosted: Fri Nov 07, 2008 4:52 pm    Post subject: Reply with quote
Thats gunna cost $$$ that i dont have
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
