flea Member
Posted: Mon Sep 29, 2008 10:17 am Post subject: trunk mechanism |
Does anyone have the parts for a 91 Camaro trunk mechanism. Not really sure what all I need. I opened the trunk this morning and the motor kept running till I unplugged it. Tells me the motor still works, but the pull down wasn't pulling down or pushing up, just the motor running. Took it all apart to try to see whats up and the plastic slide mechanism fell out in about 150,000 pieces Figure that might be why it wasn't moving, but still may be the motor gears stripped. Anywho need to replace it thinking the whole works might in order. Everything from the motor to the metal pieces that mount to the inside of the trunk area. that way Im sure to get the culprit and might even have spare parts....
Anyway a long winded request but there it is the whole trunk mechanism... |
kurfbird Member
Posted: Mon Sep 29, 2008 8:50 pm Post subject: motor |
you neeed new guides hatch motor guides that is.
go tomtopdown solutions.com they will have what you need _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
flea Member
Posted: Tue Sep 30, 2008 4:48 pm Post subject: |
cool thanks
will try them, bungees just aint working for me |
kurfbird Member
Posted: Tue Sep 30, 2008 8:35 pm Post subject: |
http://www.top-downsolutions.com/
is the web site _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
flea Member
Posted: Wed Oct 22, 2008 5:13 pm Post subject: |
| Thanks, They do have what I need. and will place my order soon, then the bungee gets the boot. |
