Posted: Sun Oct 12, 2008 4:34 pm Post subject: 2.8 VS 3.1 Injectors |
| Does anyone know the #/hr rating of both? |
Posted: Sun Oct 12, 2008 4:48 pm Post subject: |
Don't know about the 2.8, but the set I acquired and had serviced for my 3.1 were tested at 40 lbs. They were all final adjusted to 42. Not sure if that was a per hour pressure or just their tested pressure. _________________ 92 Camaro
Posted: Sun Oct 12, 2008 4:51 pm Post subject: |
40 would be the pressure, not the lb rating.
They are both in the range of 15lbs. You can put 3.1's in a 2.8 and not have any problems at all. 2.8's into a 3.1 you MIGHT run a bit lean. _________________ 2008 GMC Z71
Posted: Sun Oct 12, 2008 4:53 pm Post subject: |
| I thought 40 sounded a bit high. |
Posted: Sun Oct 12, 2008 5:37 pm Post subject: |
I've got a set of six brand new 3.8 injectors if you want them for cheap...  |
Posted: Sun Oct 12, 2008 6:14 pm Post subject: |
| TGO FWIW says 15lb for the 2.8 and 17lb for the 3.1. |
Posted: Mon Oct 13, 2008 3:56 am Post subject: |
| 17lb is 3.4l motor. |
