Posted: Mon Oct 20, 2008 2:07 pm Post subject: Bias Ply to Belted Radial |
A friend of mine here at work has a 1958 Ford pickup. He has been having troubles with keeping it on the road at speed lately. He claims that the entire front end is tight and new'ish. I asked if he had radial tires on it and he said yes. I know that could be a problem but I can't find anything online about re-aligning a pre-1965 car to post-1965 alignment spec's when putting radials on a bias ply car. Could anyone offer a site or suggestion? I'm obviously not searching for the right thing online cause I can't find it. Since he has a solid i-beam front end it could be as simple as shimming the cross beam to add in some caster. _________________ E30
