Cat Scratches!!!!
'92 camaro boss
PostPosted: Fri Aug 22, 2008 9:36 pm    Post subject: Cat Scratches!!!! Reply with quote
soooo i was hanging out with friends today, and one of my buddy's was like "WTF HAPPENED TO YOUR CAR!!!" and i went to look, and it looks like a cat either fell off my car and tried catching itself, or tried jumping up unsucessful, i've got a totaly of 6 scratces where it looks like the cat fell, they look fairly deep, i have a single stage paint job from maaco.. i believe it's semi cured, what could i use to try to make it less noticable, or make it completely gone without having maaco touch it or pay an arm and a leg to fix it
PostPosted: Fri Aug 22, 2008 11:28 pm    Post subject: Reply with quote
Just a thought, but awhile back I thought I had a cat scratching my car all up. Every week there were more and more scratches. It turned out that it's just my paint and it's horrible quality. I can tell when my car was repainted that they did a horrible prep job, the old paint underneath is still perfectly smooth.
Kage87Z
1969 Chevrolet Camaro
PostPosted: Sat Aug 23, 2008 8:28 am    Post subject: Reply with quote
Todd Beamer - 9/11
Never Forget
PostPosted: Sat Aug 23, 2008 9:57 am    Post subject: Reply with quote
I had pretty good luck with fine scratches like that using Meguiar's Scratch-X polish.
PostPosted: Mon Aug 25, 2008 8:13 am    Post subject: Reply with quote
I'm with stupid That is some good stuff if they are fairly light scratches.
I had my dog get excited to see me drive home one day and try and jump through my window. if they are really deep you can break out the wetsand paper. go with a 600 grit first, (just be VERY CAREFUL with this. 600 will take some paint off) then go with a 1500 to remove the scratches you just made with the 600, then hit it with a buffer with some cutting compound followed by the polishing compound and wax. good as new!
'92 camaro boss
PostPosted: Mon Aug 25, 2008 11:46 am    Post subject: Reply with quote
i'll go pick up some scratch-x, i looked at the stuff, but didn't buy it.. is it safe tho.. i have a single stage paint job that has "integrated" clearcoat.. and idk how that works.. but i don't want to mess up the paint..
btw about the bad prep work, i had kitty paws all on the car, and you can see where he slid and scratched
PostPosted: Mon Aug 25, 2008 1:04 pm    Post subject: Reply with quote
Single stage is easy stuff! As long as you don't rub through each layer you don't have to worry. And unless you area rubbing it with steel wool there shouldn't be an issue.
just grab a terry cloth and start rubbin!
PostPosted: Mon Aug 25, 2008 1:19 pm    Post subject: Reply with quote
Do you like the single stage other than that? I was thinking about using it for my new paint job on the camaro but wasn't sure.
'92 camaro boss
PostPosted: Mon Aug 25, 2008 1:23 pm    Post subject: Reply with quote
idk if it was the fact maaco sprayed it.. or if it's just bad paint.. but it faded already a bit..
PostPosted: Mon Aug 25, 2008 1:28 pm    Post subject: Reply with quote
faded? oh that sucks. How bad and where?
'92 camaro boss
PostPosted: Mon Aug 25, 2008 1:55 pm    Post subject: Reply with quote
all around it's not as dark as it used to be..
PostPosted: Mon Aug 25, 2008 2:34 pm    Post subject: Reply with quote
a single stage paint just needs to be light wetsanded (1500-2000), buffed and polished and it will always come back to its original shine. it is just the outer layer that is faded. wetsand that off and the under layers will bring back that shine. just be sure to keep some good wax on it to protect that outer layer as there is no clear coat to protect it.
My 1968 triumph has a one stage paint that was painted over 6 years ago and after an afternoon of buffing and waxing it shines up like it did the day after it was painted.
thats just my experience.
PostPosted: Tue Aug 26, 2008 9:30 am    Post subject: Reply with quote
It may not be fadded. Depending upon how much thinner was used, or how much air pressure was used, you can lighten/darken a paint job to match.
