MY HEADLIGHTS WONT TURN ON!
WS6FORMULA
PostPosted: Wed Jul 23, 2008 8:48 pm    Post subject: MY HEADLIGHTS WONT TURN ON! Reply with quote
why the motor goes up but no light just bought new lamps
need help please!
PostPosted: Wed Jul 23, 2008 9:38 pm    Post subject: Reply with quote
fuse? headlight switch?
'88 FORMULA
batcave
PostPosted: Wed Jul 23, 2008 9:48 pm    Post subject: Reply with quote
might be your headlight switch i got one you can try
PostPosted: Wed Jul 23, 2008 10:31 pm    Post subject: Reply with quote
if that doesnt work, go buy a fuse tester
'88 FORMULA
WS6FORMULA
PostPosted: Thu Jul 24, 2008 2:12 am    Post subject: Reply with quote
i tried the awtch out of my formula which worked.... but where is the fuse for the headlights did i just not see it or something cuz i cannot locate it
where is it
god i feel like an idiot
PostPosted: Thu Jul 24, 2008 6:22 am    Post subject: Reply with quote
There is no fuse for the headlights. In the switch, there is a thermal breaker that serves as a self-resetting fuse. The switch is connected to a fusible link which is more than likely down on the starter (there are three there), but it could be somewhwere else Wink
WS6FORMULA
PostPosted: Thu Jul 24, 2008 9:52 am    Post subject: Reply with quote
i dont like where this is going ?!?!?!?!!!!!
PostPosted: Thu Jul 24, 2008 10:01 am    Post subject: Reply with quote
So it was just the switch? Problem solved?
WS6FORMULA
PostPosted: Thu Jul 24, 2008 10:09 am    Post subject: Reply with quote
no sorry i meant i pulled the switch out of my formula which was working on the other car but then i put it on the trans am and still the headlights didnt work
PostPosted: Thu Jul 24, 2008 10:30 am    Post subject: Reply with quote
it's got to be the fusible link then. Track it down and replace it. Like Al said, there are a few located off of the starter.
WS6FORMULA
PostPosted: Thu Jul 24, 2008 10:46 am    Post subject: Reply with quote
ugh ok
god i hate pop up headlights sometimes
PostPosted: Sat Jul 26, 2008 4:43 pm    Post subject: Reply with quote
There are 2 or 3 more fusible links located on the passenger side of the radiator core support, next to the battery tray. They're easy to find and they're bolted to a distribution block.
WS6FORMULA
PostPosted: Sat Jul 26, 2008 10:16 pm    Post subject: Reply with quote
ok thanks Al im gonna get under my car tomorrw and ill see if i can spot them
PostPosted: Sat Jul 26, 2008 10:53 pm    Post subject: Reply with quote
No need to get under the car for those, just pop the hood and look down next to the passenger battery tray. Very Happy Wink
