Posted: Tue Jun 03, 2008 10:33 pm Post subject: Re: Perusing Craigslist... |
| iansane wrote: | http://seattle.craigslist.org/tac/car/705959696.html
Familiar? |
no. should it? |
Posted: Tue Jun 03, 2008 10:44 pm Post subject: |
It's Steel's car. I guess the gas bill for it caught up to him. Hard to run your race car as your daily.
Somebody should jump on that '88 Formy though, that thing is sexy as sin. |
Posted: Tue Jun 03, 2008 11:33 pm Post subject: |
| Is that the car that he hydrolocked the motor on? |
Posted: Wed Jun 04, 2008 6:34 am Post subject: |
| Dewey316 wrote: | | Is that the car that he hydrolocked the motor on? |
Posted: Wed Jun 04, 2008 10:12 am Post subject: |
Wow. I just read the post he made about that again, and realized that he fixed the hydrolock by push-starting it with the plugs still in, and then running Seafoam through it.
It's a shame because it's a nice looking RS too. |
cameron7710 Member
Posted: Wed Jun 04, 2008 10:18 am Post subject: |
ya i saw that hes been tryin to sell it for a little time now he even tryed to get rid of it on tgo and on craigslist he keeps updating with a lower price.haha im on craigslist alot tryin see if it i can find a good deal that i can afford. i really want a manual third gen _________________
Posted: Wed Jun 04, 2008 10:25 am Post subject: |
T-5 swap!!!  |
cameron7710 Member
Posted: Wed Jun 04, 2008 10:28 am Post subject: |
thought about it.but not sure yet _________________
Posted: Wed Jun 04, 2008 10:32 am Post subject: |
| It would actually be a lot easier than my swap since you don't need a new crossmember, an expensive shifter, or a wierd backwards clutch. |
cameron7710 Member
Posted: Wed Jun 04, 2008 10:40 am Post subject: |
y did u need that? _________________
Posted: Wed Jun 04, 2008 10:51 am Post subject: |
I'm running an LT1 style T-56. Do a couple searches and you should find info on the swap I did, the swap Tony did (T-5) and Paul's LS1 T56.
I think we've messed up Ian's topic enough, although you can start a new topic if you're curious about the swap. |
cameron7710 Member
Posted: Thu Jun 05, 2008 7:05 pm Post subject: |
wow looks like he really needs the car gone he just droped off another 300$ _________________
305 302eater Member
Posted: Fri Jun 06, 2008 9:37 am Post subject: |
I noticed that. Wow I must be as bored as Ian was when he made this post.  _________________ Thirdgenless |
Posted: Fri Jun 06, 2008 11:36 am Post subject: |
I just bought an '86 T/A from a guy on Craig's list for $900! The engine is in pieces and I probably need a new long block (unless I want to put a 305 in it, then I could use his rebuilt heads) and it needs paint but other than that its cherry (right Ian?!) I even got an extra set of wheels (ASAs with Kumo rubber) and a crap load of extra parts. In fact we filled TJ's blazer with all of the extra crap! So you see, it pays to keep a watchful eye on Craigs List!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Fri Jun 06, 2008 5:14 pm Post subject: |
I'd just take that block to parts plus on 84th/S.Tacoma Way. I think they still do block machining. I had my old 400 setup there.
Didn't look too bad and hopefully you can just have it honed to clean up the cylinder walls. |
Raiden Member
Posted: Fri Jun 06, 2008 8:28 pm Post subject: |
| I would go to the NAPA on 96th and pacific. the guy who used to work @ 84th and STW now know as parts plus was the $hit. He now works @ 96th and pacific, his name is Dave. Great guya & he really helped me out with many of my rebuilds! |
miamivice Member
1982 Pontiac Trans Am
Posted: Sat Jun 07, 2008 1:39 pm Post subject: |
did 92 base firebirds have the option to be purchased with a V8? have never seen that...plus it looks like the base bird had ground fxs option? is this some kind of special order car/package or something?
fiveoformula Member
Posted: Sat Jun 07, 2008 2:23 pm Post subject: |
I think the majority of the base Firebirds in '91 and '92 had the ground effects.. and they could be had with the L03 Throttle body 5.0L or a MPI 3.1L _________________
'88 FORMULA |
Posted: Sat Jun 07, 2008 2:59 pm Post subject: |
Yeah, I think it's rather rare to see base birds WITHOUT gfx. All I ever see are ones with.
That car is the splitting image of the one I test drove when I was 16. |
