And there it goes :(
PostPosted: Wed Jul 16, 2008 11:38 am    Post subject: And there it goes :( Reply with quote
The LT1 was paid in full last night and was taken off property. The kid stuck with the payment plan and I'm glad I sold it to him. He is going to learn a lot from it. I choked up a little bit to see it go. Its been my project for the last 3 years and has come a long way.
Here's how I found it:
And here's how it left:
PostPosted: Wed Jul 16, 2008 11:40 am    Post subject: Reply with quote
Was a cool looking ride. On to the next eh?
PostPosted: Wed Jul 16, 2008 11:42 am    Post subject: Reply with quote
Ya, I'm going to do much better with just one project car. Just to drop a hint I have a 454 and a Turbo 400 in the back yard that I'm going to drop into the V6 car! Twisted Evil
PostPosted: Wed Jul 16, 2008 11:50 am    Post subject: Reply with quote
Thumbs up
Will be cool to still refer to it post 454 as the V6 car... perhaps some V6 badges as well Wink
PostPosted: Wed Jul 16, 2008 12:02 pm    Post subject: Reply with quote
I was thinking of putting the quietest exhaust I could find on it with an cable side dump. Just so I can mess with the ricers. Muahaha!
The LT1 will be missed though. I learned a lot and now I'm not afraid to do any type of motor swap as long as it bolts up. My next project for the truck might be a 2002 harness swap!
PostPosted: Thu Jul 17, 2008 8:31 am    Post subject: Reply with quote
sad to see her go travis, but now you can get on to bigger and better things Smile
any drift events soon?
PostPosted: Thu Jul 17, 2008 9:00 am    Post subject: Reply with quote
I'm waiting till the new motor is in. I've hit the limits of the V6. I think I actually hit it a long time ago, i just now realized I did though. Before it comes out it will be dyno'd and hopefully 1/4 times. Just so I can see how I did.
PostPosted: Thu Jul 17, 2008 12:12 pm    Post subject: Reply with quote
You should beable to just repin the harness you have Wink
PostPosted: Thu Jul 17, 2008 3:25 pm    Post subject: Reply with quote
I hope so. If the vortec 4.3 2002 PCM is the same as the V8 then I'm in luck. A friend of mine got the harness with a motor from the junk yard and said I could have it.
PostPosted: Thu Jul 17, 2008 6:29 pm    Post subject: Reply with quote
I'm talking the harness thats in the truck right now. Its a 97/98 350 right? If so, you can put the 0411 ecm in it w/o removing the harness. You will have the same wiresystem/program as my car. It will just have the correct motor infront of it. Laughing
BTW, was digging thru old pics today. Found some of the first blue 89 Sad
PostPosted: Fri Jul 18, 2008 8:09 am    Post subject: Reply with quote
I have some pics of my first camaro on my computer screen saver. Makes me sad Sad I don't know if I ever posted pics of the before/after here on cascade. Unless someone wants to see the accident pictures I'll spare all.
Ya, the 97 computer sucks. NO SUPPORT! Will the 0411 use the same plugs? It seems to be a common swap to change it over. If I did, I'd want to save my old plugs and splice in the new one. That way I can always go back if I run into problems.
PostPosted: Fri Jul 18, 2008 8:31 am    Post subject: Reply with quote
I know you can use the same harness. You just change the plugs on the end... and you can do it w/o cutting the harness.
Does yours have 3 plugs, or two long ones?
PostPosted: Fri Jul 18, 2008 8:46 am    Post subject: Reply with quote
I think mine is 4 (+2 small ones) just like the LT1 PCM. The plug I have access to is a 2 long plug deal. If I play my cards right, I might get the vortec V6 stuff with its central all in one regulator/injector setup. Then I could inject anything!
Is the two long plugs a good thing? What does yours look like?
PostPosted: Fri Jul 18, 2008 4:43 pm    Post subject: Reply with quote
2 long is GREAT!! Thats what you need! You will just have to find the re-pin chart off um.. pacificp.com. I think 97's had something weird that had to be done to get the ac to work.
But basically, all you need is a 0411pcm, the diagram/chart, and editing program. No wireharness or engine parts needed.
