Holley 300 2bbl with stuck accel pump
PostPosted: Mon Jul 14, 2008 8:46 am    Post subject: Holley 300 2bbl with stuck accel pump Reply with quote
My boat has a 300cfm 2 barrel. I noticed that the accelerator pump is not pumping! It has an umbrella type diaphram with a linkage/cam type actuation. when you mash on it with a screw driver it squirts out a bit by the gasket so it seems like it might be a clogged line to the throught? Has anyone had this happen before?
PostPosted: Mon Jul 14, 2008 3:07 pm    Post subject: Reply with quote
sounds like the gasket or diaphram itself might be bad, or the pump discharge ball might have something restricting it.
is it a model 2300 2V?
PostPosted: Tue Jul 15, 2008 9:45 am    Post subject: Reply with quote
Not sure. I'll look when i get home.
Are there two ball checks in the accel circuit?
PostPosted: Tue Jul 15, 2008 6:14 pm    Post subject: Reply with quote
I seem to recall there only being one, in the main body of the carb down by where your accelerator pump diaphram is.
the 4150/4160 have them in the metering block.
PostPosted: Tue Jul 15, 2008 7:17 pm    Post subject: Reply with quote
I took the carb apart today in search of the illusive clog. I found none. There was minimal debri inside (which I cleaned), cleaned out the accel pump nozzle in the throught, inspected the power valve, and all of the lines in the metering block. Everything checked out fine. The accel pump only has a ball in it to keep it one way out of the bowl.
Put it back together, runs like a champ! Pump works great. I dumped some gas down the carb, cranked it up, and there ya go. All I had to do was set the bowl level. Don't know what it was! THanks for the help though!
