Need Power antenna for 88 GTA
88GTAJim
PostPosted: Thu Jul 10, 2008 7:00 pm    Post subject: Need Power antenna for 88 GTA Reply with quote
It's OK if it doesn't go up and down as long as the mast is still there. I bought a repair kit for mine and found that the mast was broke off. Duh
88 GTA LB9 5 speed 3.45 posi
PostPosted: Wed Jul 23, 2008 12:05 pm    Post subject: Reply with quote
shave it.
mount a solid mast antenna under your dash pad. i have great reception... and an ugly hole in my fender. but someday I'll finish that up.
PostPosted: Wed Jul 23, 2008 8:02 pm    Post subject: Reply with quote
shave it.
I, like tony have a big wire loop under my dashboard and get great reception. But I, UNLIKE tony. have already shaved mine and it looks sweet Cool
here's one of the fender that was shaved.
88GTAJim
PostPosted: Thu Oct 02, 2008 3:58 pm    Post subject: Reply with quote
83Z28BlackBetty wrote:
shave it.
What did you use for the wire loop and how did you attach it to the antenna cable?
PostPosted: Thu Oct 02, 2008 4:44 pm    Post subject: Reply with quote
I get crappy reception with a mast.... under the dash is just going to make it worse!
88GTAJim
PostPosted: Fri Oct 03, 2008 11:14 am    Post subject: Reply with quote
The worst part is I took the old damaged fender off and I am now waiting to find SOMETHING to install before I put the new fender back on. I cannot believe how impossible it has been to find a friggin power antenna. I would like to stay with the OEM stuff because I would like to keep it original and I don't really want to run a new antenna wire to the stereo but at this point I am ready to bail on that idea. I cant even put the friggin hood back on it yet.
PostPosted: Fri Oct 03, 2008 11:51 am    Post subject: Reply with quote
One of the techs at Mobile Radio is pretty resourceful. They may have something that will work or find something that will. No guarantees, but it won't hurt to try. Their store is down by Auto Center Way on 1st St. If you go down there, you may want to take your piece with you, IIRC ours are pretty unique in size compared to most. Talk to Jamie, he did most of the work on my car. Their phone is 377-0769.
88GTAJim
PostPosted: Fri Oct 03, 2008 12:23 pm    Post subject: Reply with quote
Thanks Al. I will try them. I have done business with them before.
kurfbird
PostPosted: Fri Oct 03, 2008 6:03 pm    Post subject: Power antenna Reply with quote
I ahve a power antenna. Mast is still there and everything. Let me know if your interested
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
88GTAJim
PostPosted: Fri Oct 03, 2008 11:04 pm    Post subject: Re: Power antenna Reply with quote
I AM Interested. I PM'd you.
Jim
kurfbird
PostPosted: Mon Oct 06, 2008 6:15 pm    Post subject: pics sent Reply with quote
pics sent
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
