It sure looks bigger than 9 inches...
PostPosted: Wed Jun 11, 2008 6:47 pm    Post subject: It sure looks bigger than 9 inches... Reply with quote
Need to flare the brake lines, pick up an S-10 T-block mount, and make brackets for the stainless lines w/ clips.
Should be able to really hunker down and stop with 13" discs in the front and 12" discs in the back!
PostPosted: Wed Jun 11, 2008 7:18 pm    Post subject: Reply with quote
Nice!
Oh, and hi to Ms. December there Embarassed
What did your torque arm mount end up looking like?
PostPosted: Wed Jun 11, 2008 7:26 pm    Post subject: Reply with quote
About what you saw. We'll see if there is enough room for it when the suspension travels. I have no worries of it's strength. If I had $160 to dump I'd have gotten the Currie one but it seems rather goofy to go that route without trying one myself first.
Just need relocation brackets and a sway bar mount but I'll go drive without both and see how it goes. Since it's the rear sway bar it shouldn't matter much on the temporary... especially in a straight line :O)
PostPosted: Thu Jun 12, 2008 9:36 am    Post subject: Reply with quote
What rear is that and what calipers? They look beefcake.
PostPosted: Thu Jun 12, 2008 11:23 am    Post subject: Reply with quote
I was gonna hit the yard Tomorrow (friday) for a speedometer gear. Its the junction block on the axle Housing that you need, correct?
PostPosted: Thu Jun 12, 2008 11:27 am    Post subject: Reply with quote
Travis, those are 89+ PBR* rear disc brakes, sitting on a modified ford 9" rear end.
*WRONG! thanks john
PostPosted: Thu Jun 12, 2008 11:51 am    Post subject: Reply with quote
No. Those are C4 front brakes, attached to a 9" rear.
PostPosted: Thu Jun 12, 2008 12:09 pm    Post subject: Reply with quote
my bad. they look alot like PBR's
EDIT
you know... no they don't Shrug
brandyland
PostPosted: Thu Jun 12, 2008 12:15 pm    Post subject: Reply with quote
That's only 9 inches?
Wow, I really do have no sense of size....... Shocked
Picture of 'Scort goes here
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Thu Jun 12, 2008 2:54 pm    Post subject: Reply with quote
Are you sure those are front disks? They look pretty thin. Also, where is the ebrake going to be if those are front calipers? Just gonna use a wood block? It looks sweet though.
PostPosted: Thu Jun 12, 2008 2:57 pm    Post subject: Reply with quote
Those rotors look thin enough that you could try using one of those wilwood mechanical calipers in addition.
PostPosted: Thu Jun 12, 2008 9:13 pm    Post subject: Reply with quote
Those are Front C4 Calipers with Rear C4 Rotors. I plan on the Wilwood mini e-Brake caliper deals.
Tony: C4 calipers (HD and Non HD) are made by PBR.
The C4 rotors are 12".
The C4 HD Rotors are 13".
My fronts are HD my rears will be the std C4. Should stop like a crazy bitch!
PostPosted: Thu Jun 12, 2008 9:18 pm    Post subject: Reply with quote
PostPosted: Thu Jun 12, 2008 10:40 pm    Post subject: Reply with quote
Nice!
PostPosted: Fri Jun 13, 2008 6:35 am    Post subject: Reply with quote
Laughing so hard it hurts
