tuner pro rt Q's
Raiden
PostPosted: Mon Sep 15, 2008 9:41 pm    Post subject: tuner pro rt Q's Reply with quote
I"ve just started using tuner pro and I can not figure out how to read the aldl tuner pro file. I used to use craig moates date master ecm 852. I would like to start using tuner pro and eventually use an ostirch, but i've yet to pull the tirgger as I can't get the tuner pro aldl files. I can record the tuner pro data file but i can't read the data I record.
How do I read the recorded data I log on tuner pro rt for the aldl files?
Thank You Cool
PostPosted: Tue Sep 16, 2008 6:53 am    Post subject: Reply with quote
Did you find the right ALDL files from moates.net in their download section? You need to download the right *.ads file for your ecm from
http://www.moates.net/info_pages.php?pages_id=14
Magman
1990 Chevrolet Camaro IROC-Z
PostPosted: Tue Sep 16, 2008 9:08 pm    Post subject: Reply with quote
After you've recorded it, you need to go to ALDL Setup. Click on Export selected session to CSV. Save that file to a folder you can get to easily. I'm using Vista so I save it directly to desktop cause it goes to cyberspace if I don't. Close TP and open the file. It displays in MS Excel. That should do it, provided it was recorded correctly.
1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
11.78 @ 115 w/1.59 60' (8-18-2012)
