broken bolts =[
WS6FORMULA
PostPosted: Sun May 18, 2008 11:53 am    Post subject: broken bolts =[ Reply with quote
so pulled my one tire fire rear end and was goin to swap in the posi but when i was trying to remove the control arm botls of the rear end they broke so im in need of 2 control arm bolts and i went to home depot and other hardware stores no one has them just wondering if you guys know where i could get some of them ... is there a place to order them???
PostPosted: Sun May 18, 2008 12:30 pm    Post subject: Reply with quote
there are two places on the west side you need to try. the first is "suburban ace hardware" in aloha, they have a MASSIVE hardware selection. they are on 185th and Tualitin Valley highway.
3470 SW 185th Ave Aloha, OR 97006-3129
(503) 649-5555
then if they don't have it, get back on hwy 26 and head a little further west, get off on the "shute road" exit and make a right onto evergreen rd, then a left on 25th after you pass the airport. about a half a mile down is a "Fastenall". i have heard they have everything, but as suburban ace alwasy has what i need i have never been in there.
Fastenal
1800 NE 25th Ave Hillsboro, OR 97124-5982
(503) 615-8616
you could also hit the junkyard and score some less rusty lass brittle ones. the dealership would also be able to get them for you i bet.
PostPosted: Sun May 18, 2008 3:57 pm    Post subject: Reply with quote
Winks Hardware.
Parkrose Hardware.
Vancouver Bolt.
Tacoma Screw.
You're not going to find the same style bolt. They are a stepped bolt and not reproduced. Luckily the LCA bolts are unlike the Panhard bolt. Both holes are the same size. So get a set of bolts/nuts that have the same diameter as the fattest part of the stock bolt.
Or hit the Wrecking yard.
PostPosted: Sun May 18, 2008 5:33 pm    Post subject: Reply with quote
I have the bolts that connect the LCA's to the axle, not the ones that tie the LCA's into the chassis.
if you don't mind the drive here you can have em both.
PostPosted: Sun May 18, 2008 7:37 pm    Post subject: Reply with quote
Same bolts.
WS6FORMULA
PostPosted: Sun May 18, 2008 7:44 pm    Post subject: Reply with quote
ok well that was i was thinking when i went to parkrose hardware just get the botl that is equivilent to the fattest part of the stock ones but the thread is way to short compared to the stock one.....
where do you live?
PostPosted: Sun May 18, 2008 9:08 pm    Post subject: Reply with quote
You have a PM.
