LT1 plus all wiring FOR SALE
WS6FORMULA
PostPosted: Thu Mar 06, 2008 10:34 am    Post subject: LT1 plus all wiring FOR SALE Reply with quote
i have a lt1 motor all stock sitting in my garage had it for about 6 months took it out of a 95 z28 it had 90000 miles on it it ran perfect no smoke or anything i have all the wiring. i was goin to swap it into my fourth gen but later i sold it. if you want pictuers just pm me and im asking 700.00 i am felxible just need to get it out of here maybe a trade for some cool stuff?!?!?
PostPosted: Thu Mar 13, 2008 11:41 am    Post subject: Reply with quote
This is a damn good deal for anyone looking for an easy 300-400hp motor. Plus the 95 is obdII and has the updated optispark and knock sensor module.
PostPosted: Thu Mar 13, 2008 3:22 pm    Post subject: Reply with quote
what kind of condition is the motor in? needs a rebuild I assume?
'88 FORMULA
WS6FORMULA
PostPosted: Thu Mar 13, 2008 4:03 pm    Post subject: Reply with quote
the motor will not need a rebuild I took it out of a car that was totaled but didn't damage any of the drivetrain. I live in portland and I drove the car back from beaverton to portland and it runs excellent no smoke or anything you can come do a compression check if you want and im selling everything for it mainfolds computer all wiring blck heads etc complete stock LT1 motor
Brizio
1985 Chevrolet Camaro IROC-Z
PostPosted: Tue Mar 18, 2008 1:40 pm    Post subject: Reply with quote
Do you have transmission and rear axle?
WS6FORMULA
PostPosted: Tue Mar 18, 2008 7:16 pm    Post subject: Reply with quote
no I don't just motor and harness
PostPosted: Tue Mar 18, 2008 7:24 pm    Post subject: Reply with quote
Too bad you put this up at the wrong time for me. Rear end swap took a good chunk of change from me Sad
WS6FORMULA
PostPosted: Tue Mar 18, 2008 8:56 pm    Post subject: Reply with quote
so you were interested?
PostPosted: Tue Mar 18, 2008 9:39 pm    Post subject: Reply with quote
I have to pass for now. I'm always looking out for deals like that, but it's still early in the build process for me. I want to get the chassis and suspension up to par before engine and tranny work, also I have no place to keep it while waiting.
I do have the posi drum rear with a 3.08 gear from my 89 if you're still interested. It sits in front of my garage at the moment.
WS6FORMULA
PostPosted: Tue Mar 18, 2008 9:55 pm    Post subject: Reply with quote
o ok yeah that's understandable but I am still looking for the posi rear end but actually my dad just bought an 84 transam and it has a disc rear end im gonna pull the rear end cover to check if its a posi and if it is im gonna buy that one from my dad but if its a open ill most likely be interest in yours
PostPosted: Wed Mar 19, 2008 1:14 pm    Post subject: Reply with quote
it includes all accessories and stuff. like i could fire it up if i gave it electricity, fuel and coolant flow?
when you say "all wiring"... are the PCM and ECM modules included?
does it have AC? has the system been breached or does it still contain the coolant?
PostPosted: Wed Mar 19, 2008 4:30 pm    Post subject: Reply with quote
I think sitting in garage for 4 months would yeild an unfull a/c system.
mrpopo573
PostPosted: Wed Mar 19, 2008 5:34 pm    Post subject: Reply with quote
I don't think there is a way to pull a motor without making a hole in the seal of the AC system Tony.
305302eater wrote:
2000 Maxima SE 5 Speed VQ30
PostPosted: Wed Mar 19, 2008 7:25 pm    Post subject: Reply with quote
Duh
well the "does it have ac" part is still a valid question.
PostPosted: Mon Mar 24, 2008 1:40 pm    Post subject: Reply with quote
I'd like to come check it out sometime, where are you located?
'88 FORMULA
PostPosted: Tue Mar 25, 2008 9:13 am    Post subject: Reply with quote
The AC pump hits the crossmember when swapped into a 3rd gen. The dealer offers an AC delete pulley for $75 that fixes the problem. Other than that, it would be a huge royal pain to locate it down in the stock position. I think you can swap it over to a 3rd gen AC though. I think a guy on TGO did that, TexanLT1 or something. Its an all white engine.
Mangus
1989 Pontiac Trans Am
PostPosted: Sat Mar 29, 2008 3:49 pm    Post subject: Reply with quote
No, it's OBDI. It just uses an OBDII connector. Smile
Sounds like a good deal. Too bad I have neither the storage space nor a vehicle to throw it in. It could be fun to play around with.
305 302eater
PostPosted: Sun Mar 30, 2008 9:41 am    Post subject: Reply with quote
How hard is it to swap. If its not to hard I might be interested. Cool
Thirdgenless
PostPosted: Sun Mar 30, 2008 11:15 am    Post subject: Reply with quote
http://www.thirdgen.org/techboard/engine-swap/400030-common-lt1-swap-questions.html
You should also ask Travis, as he has done that swap in his black car.
PostPosted: Sat Apr 26, 2008 9:26 pm    Post subject: Reply with quote
you ever find a buyer? or you still selling?
'88 FORMULA
