3 series carrier.
PostPosted: Fri Apr 18, 2008 9:25 pm    Post subject: 3 series carrier. Reply with quote
Need one because I did some damage to the internal threads on my extra 3.73 carrier after the cross pin bolt broke.
Don't need the ring gear, just the carrier itself.
might go to the JY, but thought I'd try here at first.
PostPosted: Sat Apr 19, 2008 8:12 am    Post subject: Reply with quote
JY is $50.
Why not just use the one from your other rear if you need to swap axles for some reason?
Count the splines on the axles. If they're 28 you should put that axle in and you can have the Chevette OPEN diff... if today goes well!
PostPosted: Sat Apr 19, 2008 9:01 am    Post subject: Reply with quote
only 26 spline unfortunately.
$50 bucks eh.....might be cheaper if I just see if I can find two 28 spline axles and keep the 26ers around as spares.
STEEL
PostPosted: Sat Apr 19, 2008 9:11 am    Post subject: Reply with quote
Because I know nothing of rear-end gears, I am going to say I have a complete 10 bolt out of my 91, will that help at all?
PostPosted: Sat Apr 19, 2008 7:37 pm    Post subject: Reply with quote
That will be 28spline. Depending upon the gears will determine if its S2 or S3.
PostPosted: Sat Apr 19, 2008 7:40 pm    Post subject: Reply with quote
I'm going to go out on a limb and guess that if that's the stock rear end, it's either a 3.08 (5-spd) or a 2.73 (auto), both of which I believe are 2 series. At least that's what I got from reading several posts on TGO.
PostPosted: Sun Apr 20, 2008 10:00 am    Post subject: Reply with quote
Bought a whole 3.42 rear yesterday.
Admins, you can lock or delete this.
PostPosted: Sun Apr 20, 2008 11:26 am    Post subject: Reply with quote
You can delete your own posts :O)
PostPosted: Sun Apr 20, 2008 1:18 pm    Post subject: Reply with quote
negative.
Just "quote" and "edit" options available.
PostPosted: Sun Apr 20, 2008 2:16 pm    Post subject: Reply with quote
Not once the post is been replied to.
PostPosted: Sun Apr 20, 2008 6:51 pm    Post subject: Reply with quote
Ahh I see. I knew I'd deleted them before.
