Going through Idler Arms like beer
PostPosted: Mon Feb 25, 2008 7:28 pm    Post subject: Going through Idler Arms like beer Reply with quote
I've toasted 3 idler arms in 3000miles.
Tie rods/Center link DO check out okay.
Ball joints are good.
What gives?
PostPosted: Mon Feb 25, 2008 7:43 pm    Post subject: Reply with quote
What vehicle? If you're that hard on them you might want to step up to the Napa Chassis line. They re-engineer all the suspension parts to be much tougher then stock.
PostPosted: Mon Feb 25, 2008 7:44 pm    Post subject: Reply with quote
what part of the idler is failing?
PostPosted: Mon Feb 25, 2008 8:50 pm    Post subject: Reply with quote
The joint on the arm.
The Maro.
PostPosted: Mon Feb 25, 2008 10:10 pm    Post subject: Reply with quote
All I can think of is crap arms. Wonder which kind of joint your arm has? The crimped style are pretty crappy. I've gone through exactly 1 arm in 280k miles.
brandyland
PostPosted: Mon Feb 25, 2008 10:17 pm    Post subject: Reply with quote
Like beer?
Down the hatch
That could be considered to be a callosal waste of beer!
Is nothing sacred anymore?
Picture of 'Scort goes here
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Mon Feb 25, 2008 10:26 pm    Post subject: Reply with quote
Down the hatch
the only other thing I could think of, is that your centerlink is somehow putting some weird up/down force on it, and causing it to wear abnormally. But I would think to do that, you would have to have things pretty jacked up to get the centerlink that far off.
PostPosted: Tue Feb 26, 2008 4:58 am    Post subject: Reply with quote
On my v6 one(havent checked vCool, you could adjust the height of it. My only guess is, its getting mounted to high, or to low, and its binding the joint. But IMO, that would cause funky steering also.
PostPosted: Tue Feb 26, 2008 7:50 am    Post subject: Reply with quote
Maybe your alignment is off and its causing excessive pressure on the idler? Did you make sure the level of the idler matched the steering arm?
PostPosted: Tue Feb 26, 2008 6:22 pm    Post subject: Reply with quote
Even if it was off it shouldn't exhibit this kind of wear. Looks like there are improved designs as brandon says.
I put the last one in the same position as the alignment shop had set it the last time I had an alignment.
